-   -   Twin Plug Setup Question (http://forums.pelicanparts.com/911-engine-rebuilding-forum/240738-twin-plug-setup-question.html)
WydRyd 09-13-2005 05:55 AM
OK, when I had my engine rebuilt, I had my heads twin-plugged prep'd, however, I'm only running single plug for now, until I source a good used 964/993 Distributor.
Would I need to modify the 964/993 distributor to work on my Carrera motor, or would it be a simple swap out?
I know I have to run a signal splitter off the OEM inition, twin Crane HI-6 Fireball ignition systems & twin Crane LX92 coils, but is there any machining required on the twin plug distributor to make it fit/work?
Advice appreciated :)
Steve@Rennsport 09-13-2005 09:20 AM
Merv:
Its a drop-in on Motronic motors with no modifications required. :)
ChrisBennet 09-13-2005 11:03 AM
You don't need to mod the distributor but I had to modify the heater ducting to make everything fit.
-Chris
Bobboloo 09-13-2005 11:12 AM
Heater ducting, what's that?
cue Randy Newman:
"I love L.A." "We love it!"
ChrisBennet 09-13-2005 11:16 AM
Extra weight? :D
-Chris
WydRyd 09-13-2005 03:45 PM
Thanks Steve & Chris :D
Also, what's the going rate for a good used 964/993 dizzy these days?
Anyone have one lying around?
blue82coupe 09-13-2005 05:07 PM
Steve Timmons( IG) quoted me a price of 475.00 shipped, with a new belt. Dan
strokher racing 09-13-2005 08:58 PM
Merv you better make sure your turbo pipe will clear. I have a feeling you will have clearance issues here
Eric Hood
WydRyd 09-13-2005 09:32 PM
The pre-IC charge air pipes will be re-done soon, after I install the new headers. I'll take all that into consideration :cool:
strokher racing 09-13-2005 09:40 PM
Gonna be pretty hard to make that clear especially with the larger pipe you will run with that "small turbo" I am sure it can be done though just wont work out of the box. For something to use on mock up you might try flexible dryer hose like material it works real nice for things like that
Eric Hood
WydRyd 09-13-2005 10:21 PM
T70, a small Turbo? :confused: :D :cool:
Agree tho! The 4" inlet to the compressor will be a huge mutha to route around that engine bay :eek:
Thanks for the tip re:flex dryer hose.
jacko241 09-14-2005 04:54 AM
Have you considered the Electromotive cranktrigger ignition system? I run that setup on my race car and it was easy to set up, has been trouble free, and is almost infinitely adjustable.
Wayne 962 09-15-2005 10:55 PM
Bosch rebuilt is a little more than $700, and guaranteed to work like new:
http://www.pelicanparts.com/cgi-bin/ksearch/PEL_search.cgi?command=show_part_page&please_wait= N&make=POR&model=911L&section=elignt&page=3&bookma rk=14&part_number=H-602-015-AX
-Wayne
Porsche84 09-18-2005 05:36 PM
Merv
I twin plugged my 3.2 a few years ago. I got the 964 dist and replaced the belt. Thought I was good until I learned that I needed a "converter/igniter". The one I purchased was made by Andial and it cost $500 to $600. Think about that on top of the cost of the 964 distributor and it may be better to go crankfire as suggested above.
Henry Schmidt 09-21-2005 10:55 AM
ANOTHER OPTION:
TEST IS ON GOING BUT SO FAR SO GGOD AND WE'RE READY TO SHIP.
http://forums.pelicanparts.com/uploa...1127325143.jpg http://forums.pelicanparts.com/uploa...1127325158.jpg
http://forums.pelicanparts.com/uploa...1127325266.jpg
strokher racing 09-22-2005 08:53 PM
What is the price on those?
Henry Schmidt 09-22-2005 10:52 PM
About $1200. They come with a new cap and rotor.
We can make them for most 911/ 930 applications.
Wayne 962 09-22-2005 11:19 PM
We're waiting on a kit similar to that one that uses the Jaguar cap and a custom rotor...
-Wayne
kenikh 09-23-2005 07:23 AM
When are the ones for early cars coming online?
Henry Schmidt 09-23-2005 09:06 AM
-Wayne
What kit is that?
We're working on one as we speak.
