WydRyd's Avatar
Question Twin Plug Setup Question
OK, when I had my engine rebuilt, I had my heads twin-plugged prep'd, however, I'm only running single plug for now, until I source a good used 964/993 Distributor.
Would I need to modify the 964/993 distributor to work on my Carrera motor, or would it be a simple swap out?
I know I have to run a signal splitter off the OEM inition, twin Crane HI-6 Fireball ignition systems & twin Crane LX92 coils, but is there any machining required on the twin plug distributor to make it fit/work?
Advice appreciated
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 09-13-2005, 05:55 AM
Merv:
Its a drop-in on Motronic motors with no modifications required.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 09-13-2005, 09:20 AM
Irrationally exuberant
ChrisBennet's Avatar
You don't need to mod the distributor but I had to modify the heater ducting to make everything fit.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 09-13-2005, 11:03 AM
Warren Hall Student
Bobboloo's Avatar
Heater ducting, what's that?
cue Randy Newman:
"I love L.A." "We love it!"
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 09-13-2005, 11:12 AM
Extra weight?
-Chris
Old 09-13-2005, 11:16 AM
WydRyd's Avatar
Thanks Steve & Chris
Also, what's the going rate for a good used 964/993 dizzy these days?
Anyone have one lying around?
Merv
'89 911 Turbo Cab
Old 09-13-2005, 03:45 PM
blue82coupe's Avatar
Steve Timmons( IG) quoted me a price of 475.00 shipped, with a new belt. Dan
I have plenty of lead for my pencil... just not enough paper to write on..
82SC with 95 993 engine
2004 Ford Powerstroke
Old 09-13-2005, 05:07 PM
Merv you better make sure your turbo pipe will clear. I have a feeling you will have clearance issues here
Eric Hood
Old 09-13-2005, 08:58 PM
WydRyd's Avatar
The pre-IC charge air pipes will be re-done soon, after I install the new headers. I'll take all that into consideration
Merv
'89 911 Turbo Cab
Old 09-13-2005, 09:32 PM
Gonna be pretty hard to make that clear especially with the larger pipe you will run with that "small turbo" I am sure it can be done though just wont work out of the box. For something to use on mock up you might try flexible dryer hose like material it works real nice for things like that
Eric Hood
Old 09-13-2005, 09:40 PM
WydRyd's Avatar
T70, a small Turbo?
Agree tho! The 4" inlet to the compressor will be a huge mutha to route around that engine bay
Thanks for the tip re:flex dryer hose.
Merv
'89 911 Turbo Cab
Old 09-13-2005, 10:21 PM
jacko241's Avatar
Have you considered the Electromotive cranktrigger ignition system? I run that setup on my race car and it was easy to set up, has been trouble free, and is almost infinitely adjustable.
Joe
996 GT3 RSR
Old 09-14-2005, 04:54 AM
Author of "101 Projects"
Wayne 962's Avatar
Bosch rebuilt is a little more than $700, and guaranteed to work like new:
http://www.pelicanparts.com/cgi-bin/ksearch/PEL_search.cgi?command=show_part_page&please_wait=N&make=POR&model=911L&section=elignt&page=3&bookmark=14&part_number=H-602-015-AX
-Wayne
Old 09-15-2005, 10:55 PM
Grand Am/IMSA Data Guy
Porsche84's Avatar
Merv
I twin plugged my 3.2 a few years ago. I got the 964 dist and replaced the belt. Thought I was good until I learned that I needed a "converter/igniter". The one I purchased was made by Andial and it cost $500 to $600. Think about that on top of the cost of the 964 distributor and it may be better to go crankfire as suggested above.
Jerry Austin
AIM Data Products Dealer
84 911 3.6 track car - Sold
Morris Minor Van with S2000 running gear
http://austinmotorsportsllc.com/
Old 09-18-2005, 05:36 PM
Try not, Do or Do not
Henry Schmidt's Avatar
ANOTHER OPTION:
TEST IS ON GOING BUT SO FAR SO GGOD AND WE'RE READY TO SHIP.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 09-21-2005, 10:55 AM
What is the price on those?
Old 09-22-2005, 08:53 PM
About $1200. They come with a new cap and rotor.
We can make them for most 911/ 930 applications.
Henry Schmidt
Ph: 760-728-3062
Old 09-22-2005, 10:52 PM
3 restos WIP = psycho
kenikh's Avatar
When are the ones for early cars coming online?
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 09-23-2005, 07:23 AM
Originally posted by Wayne at Pelican Parts
We're waiting on a kit similar to that one that uses the Jaguar cap and a custom rotor...
-Wayne
What kit is that?
We're working on one as we speak.
Henry Schmidt
Ph: 760-728-3062
Old 09-23-2005, 09:06 AM
