-   -   TEC3r software help (http://forums.pelicanparts.com/911-engine-rebuilding-forum/242766-tec3r-software-help.html)
David 10-22-2005 07:10 PM
I'd go Motec if it was in my budget and I still might if I increase my budget before I'm done. One concern I have with Motec is the M48 doesn't have enough ignition outputs so you'd have to add an expander. The Autronic SMC has 4 ignition outputs so you could send 3 signals to a CDI and split the 3 CDI outputs to drive 6 waste spark coils. Of course the Motec M600 would solve this problem but it's over a grand more money.
snowman 10-22-2005 09:11 PM
Its only money.
Rob 930 10-25-2005 09:36 AM
Don,
Are there any well-respected Porsche turbo/EFI tuners in your area? If so, what ECUs do they specialize in? I hope you can get some local support on this.
Rob
DonE 10-25-2005 10:01 AM
Balance Performance - Motec
They tune forced induction Japanese and German cars.
DonE 10-25-2005 03:03 PM
Electromotive called to say the IAC circuit was bad. Not sure whether to laugh or cry...
They want to do more tests overnight - simulate 8700 rpm using all sensors, injectors, spark, etc....
snowman 10-25-2005 09:46 PM
Jump up and down with JOY. Joy to be able to help them fix their bugs. Your labor is FREE! Seems like they must have changed management there.
briankeithsmith 10-26-2005 04:52 AM
Don:
Sorry to hear about this man. Its incredible.
Makes me glad I have the old TECIII and not the TECIII-R.
Brian
ANTONIO 10-26-2005 05:18 AM
Don,
I will very much consider the Dta Pro-8 unit,bullet proof.,cheers,Antonio.
goldgunner 11-07-2005 09:49 AM
Don
Any new developments?
And, could you offer any tips, how you did its, photos, as to:
Locating the Electromotive:
DFU's
ECU
ECU Cable Runs
Relay and Fuse (Power Harness) Components
DonE 11-07-2005 06:24 PM
The system works, kind of....
It now holds idle, but here are the other bugs:
> under boost, the coolant sensor is unstable
> during decel, the TPS will not show fully closed voltage
> MAP sensor is unstable at every RPM point (differs by up to 10 kPa plus or minus)
rick conrath 12-02-2005 07:49 AM
Hey Antonio....know of any good Motec units for sale?
Rick
911teo 12-06-2005 08:41 AM
There was one in the classified a while back...
Cheeky....
