I'd go Motec if it was in my budget and I still might if I increase my budget before I'm done. One concern I have with Motec is the M48 doesn't have enough ignition outputs so you'd have to add an expander. The Autronic SMC has 4 ignition outputs so you could send 3 signals to a CDI and split the 3 CDI outputs to drive 6 waste spark coils. Of course the Motec M600 would solve this problem but it's over a grand more money.
Its only money.
Don,
Are there any well-respected Porsche turbo/EFI tuners in your area? If so, what ECUs do they specialize in? I hope you can get some local support on this. Rob |
Balance Performance - Motec
They tune forced induction Japanese and German cars. |
Electromotive called to say the IAC circuit was bad. Not sure whether to laugh or cry...
They want to do more tests overnight - simulate 8700 rpm using all sensors, injectors, spark, etc.... |
Jump up and down with JOY. Joy to be able to help them fix their bugs. Your labor is FREE! Seems like they must have changed management there.
Don:
Sorry to hear about this man. Its incredible. Makes me glad I have the old TECIII and not the TECIII-R. Brian |
Don,
I will very much consider the Dta Pro-8 unit,bullet proof.,cheers,Antonio. |
Don
Any new developments? And, could you offer any tips, how you did its, photos, as to: Locating the Electromotive: DFU's ECU ECU Cable Runs Relay and Fuse (Power Harness) Components |
The system works, kind of....
It now holds idle, but here are the other bugs: > under boost, the coolant sensor is unstable > during decel, the TPS will not show fully closed voltage > MAP sensor is unstable at every RPM point (differs by up to 10 kPa plus or minus) |
Hey Antonio....know of any good Motec units for sale?
Rick |
There was one in the classified a while back...
Cheeky.... |
| All times are GMT -8. The time now is 03:47 AM. |
