-   -   Cam, how bad is this? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/243024-cam-how-bad.html)
goose2 09-26-2005 12:38 PM
This is in a motor that supposedly had a total rebuild less than 25k miles ago...#5 intake lobe. How long would it take for this to happen? Should I trust this rebuild? (1980 3.0CIS) Opinions?http://forums.pelicanparts.com/uploa...1127763406.jpg
#6 intake lobehttp://forums.pelicanparts.com/uploa...1127763495.jpg
aturboman 09-26-2005 01:22 PM
I have an ex-Porsche factory tech freind who told me there was a bad batch of cams in some 3.0 engines. Apparently not heat treated correctly. It will run that way for awhile but eventually when you get to the unhardened surface the lobe will ware out in very short order. It needs to be replaced or reground by someone like Web Cam. Once the thing comes apart all that finely gound metal will get everywhere in your engine and you'll need to do a rebuild after that. Do it now before it gets real expensive.
andrew15 09-26-2005 02:26 PM
I have a pair of 3.0 Cams in nice shape if you decide to replace.
Andrew M
camgrinder 09-27-2005 08:46 AM
That is typical wear for a 100k plus mileage 3.0 litre engine.
I too have seen these lousy 3.0 cams, however I do not believe it was a heat treat problem. The camshafts I have seen had some manufacturing issues. The face was not parallel to the rocker. This caused the wear on one side of the lobe you see there.
My guess is, the engine was rebuilt and the cams used as is. They were not repaired.
If your looking to buy this engine, the cams can be repaired, or you could grind them to a "DC13" or "964" specs for a little more power.
goose2 09-27-2005 09:16 AM
Thanks for the advice John and all. I've already bought this motorand am just checking it out before I install it in my 914. Obviously the cam will have to be replaced. It's interesting that the other cam appears to be new....the black oxide finish is still on the heel of the cam. It appears the rebuilder replaced one cam and re-used the other.
