Installing rings
I have a new set of pistons and I need to install the rings. Is it worth the effort and expense to get the more expensive (~$50) piston ring tool that better supports the ring as it is expanded, or is the $4.99 tool sufficient?
Air Medal or two
did mine just fine w.o. said 50.00 tool
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
Bullet Bob,
Just use your fingers. I don't have my book with me, but I believe that Wayne suggests using your fingers, and that worked well for me. There isn't very much tension on the rings, and you can easily spread them with your fingers. I liked the control, as you only want to spread them enough to install them, and no more (they will break). Rex
1975 911s 1997 Saab 900s |
MBruns for President
To put the rings on the pistons I would use your fingers.
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
In lieu of fingers. which could result in ring distortion if not careful, Lisle sells a ring installation tool that's fairly inexpensive ($10-$15?). You don't have to spend $50. They also make a take-apart ring compressor which you'll also need (although fingers have been known to compress them as well).
Sherwood |
Fingers
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
Irrationally exuberant
For under 98mm I use fingers. For 98mm and above I feel more comfortable using a cheap (bluepoint?) articulated one that supports the rings a little better.
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
fancytown
If you're wearing nitrile/latex gloves, the corner of the piston ring can get cought on them, so be careful.
I bought my ring expander at Sears....probably was the Lisle one. Very easy to control and expand "just enough" to install on piston.
all cars sold. |
I slip the rings on using a very thin shim on the ends to keep them from digging into the pistons. Fingers with the shims (can use a 004 feeler blade).
-Andy
72 Carrera RS replica, Spec 911 racer |
Unregistered
I used a $6 tool I bought from Poop boys back in my serious horsepower drag racing days, worked just fine.
