Ralph, thanks again for the info. Your discussion with Eric brought back memories on the battery in the computer. I am pretty sure that the battery must be done for by now and I will have to find out if that means the original programming is lost or maintained as emproms. I did see some of the same numbers on some of the sensors but the numbers are starting to wear off so it confirms what you are saying. I might take you guys up on the road trip offer but that is probably a ways off now.
Since my last post I have removed the intake manifolds, upper water manifolds, some more oil lines and bottom left water manifold. I am unable to get the right water manifold off due to interference by the main oil line that comes off the bottom of the right case. I can't get the manifold off because it hits the oil line block and I can't get the oil line block off because the manifold is in the way. I may have to wait until the heads come off on that side. I also have removed the oil pump on the cams. I was going to try and remove the cam covers tonight but ran into another snag. I really need to remove the water pumps first but need to get the impeller blades off before I can do that. I will probably have to make up a special tool for this and I am not sure if I need to heat the impeller up or what. I remember having to deal with this many years ago when I repaired the left one which had a leak but my memory is failing as to specifics. I am going to have to get some professional advice at this point.
Doesn't want/need a 3.6L
Hi Heli,
I can help you with some of your questions (this time without even asking! )First, the programming should not be affected by having dead batteries, the information should be stored and retained in the various eproms. That shouldn't be an issue for you(hopefully!) I think that I may have mentioned this in an earlier post, but you can take heads & manifolds off together. This alleviates the issue with trying to get the oil line block/manifold off independently of each other. This is how the motors are disassembled at Motorsport. Since it appears that you will end up going this route, BE VERY CAREFUL WHEN REMOVING THE CYLINDERS AND MAKE SURE THEY COME OFF STRAIGHT! Remember, they are one unit and not individual pieces like an air-cooled motor. If not paying careful attention, you may damage/break some very expensive parts, and possibly the rings as well. Once these are off, you'll obviously won't have any problems removing the oil block. Upon reassembly, the components are fitted in reverse of above, namely as a complete unit. The water pumps do not require a special tool for removal, but the shaft/keyway may be corroded and can be a real PITA (like you already know). The guys often had to use a torch to warm things up a bit before being able to remove them. Good Luck! Ralph P.S. - Looking good! |
Wildman Emeritus
Bearing Source:
Southern Precision Bearing 2939 46TH Ave. North St. Petersburg, FL 33714 888-274-2219 Bill Lund is the person to talk to. If it's a bearing, he can get it at a fair price. Likely the sphericals are Ina manufacture if they are metric. Hope this helps.
Mike Andrew 1980 SCWDP 2024 Suby Forester 2018 BMW X1- Wife's 2000 Boxter - Sold |
Registered Cruiser
Great thread. What are the specs on this car and motor?
87' Carmine Red Carrera - Keeper 82' Silver SC - Sold 79' Gran Prix White SC - Sold 05' Black C2S - Daily driver I have never really completely understood anything. |
Keep the updates coming! Neat project.
Chris https://dergarage.com ‘11 987.2 CS, '01 986S, '11 958S, '24 R1T, '87 Defender V8 |
Todays progress seemed a little better. In the morning I had a nice conversation with Neil Harvey at Performance Developments who has done a lot of these motors. I had found an old card of his company from the earlier days in some old paperwork which had been given to me back in around 1997 or 98 when I had been down at Willow Springs with the car. I found his site on the internet which has a picture of a 962 type motor and some of the head modifications he was doing. This may be appropriate for my engine so I think I will be having him do the machine work. He has offered me the opportunity to work with one of his machinist to do any tear down that I am unable to do without special tools and then inspect and clean the parts down to the sub assemblies. This will allow me to take more pictures and document this project further. He of course has put the fear of the unknown in me with all the things that need to be checked and some of the problems that I hope I don't have with my engine in which parts are getting more rare by the year.
As was noted in my recent post the difficulties were partially solved. I removed the impellers by putting some Marvel oil on the shaft and using a small slide hammer with 2 small hooks and gently tapping each hole in an alternating manner. The left side came off much easier. Note the picture below that shows what I found on the left side only. Fortunately it does not corrode into the case and will clean up fine. With the water pumps then removed, I was able to take off the cam covers. I tried my best but was unable to save the gaskets. Note the cam gears on one of the pictures below with a spanner type nut on the end. I am wondering if I can just leave them on the cams. The gears look pristine from what I can tell as there is no evidence of overheating or any pitting what so ever. The cam lobes look good too. I have also posted a close up of one of the scavenge oil pumps. I then removed the oil filter housing and have a picture of that. I finally removed the pully. An impact wrench didn't budge the bolt so I heated it up with a hand held heat gun an the bolt then came off easily. The rest of the night I spent putting parts in bags and bins so they don't get mixed up. Thanks Mike and Ralph for the info.
tag
As I mentioned in one of the beginning posts, you will be in great shape if you have Neil guiding you. His resume is impeccable, not only with Porsche engines, but he also was an engineer with Toyota's GTP program and even further back in time was a big-wig with the Brabham-BMW team and their 1.5L turbo motors. Looking forward to following your progress. Ralph |
Well, I continue to plod along. I am going to continue to disassemble the motor until I can't go anymore with my resources. Last night I removed the cams and cam holders. They actually came off quite easily with removal of the cams first, followed by nut removal and then some light taps with the soft blow hammer. Next the cyclinders were removed enbloc as well as the shims. Interestingly, the head bolts came off with the heads as they are stuck under the valve springs. the last items to be removed were the oil tube block, oil pressure spring, and intermediate cam gear and housing. The head studs all are magnetic so it looks like I don't have Dilavar. Everything so far looks in good shape including the cylinders, cam bearings, cam gears and the cams themselves making me wonder if I really did need to take it apart. Atleast now I know and will be able to sleep at nights. I didn't work on the engine today as I went to Buttonwillow raceway and let my son drive my FM. It was fun to watch him drive a real race car and race track for the rist time. None-the-less he did manage to have one spin off track so we do have a little mess to clean up (those of you who have been to Buttonwillow know how caustic the dirt is there). This weekend I may try to split the case and do the final disassembly but, I am thinking of going to the SF Auto Show. I then can do some cleaning and organizing before taking things off to the machine shop for evaluation and treatment! More picture below:
Great photos, thank you! I think a lot of people are following along even though they are not necessarily posting. cheers!
Andy |
Banned
helidoc,
It seems that you got some wear on the cam bearings, so it was'nt a bad idea to take it apart, also I think it was running a little rich, but I may be wrong, the valve faces seem to have to much carbon on them, but I guess it also depends on how the car actually was driven.,either way enjoy your project.,kind regards, Antonio. |
Forced Induction Junkie
helidoc,
Way to go!!! What a series of posts. On your last post of photos. The last photo in the column where the piston/rod assembly is sticking out of the block......is that a piston squirter in the lower right hand side of the spigot? That is one serious squirter if it is. ![]() It is interesting that the valve pocket area is so carboned up. Yet in the photos of the piston tops, there is practically no carbon build up. May be a case of the engine being test fired by the seller but never warmed up and under load?
Dave '85 930 Factory Special Wishes Flachbau Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P Last edited by WERK I; 11-19-2005 at 07:42 AM.. |
MBruns for President
Cool head studs - and thanks for the progress report.
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Helidoc,
Looking great! Are you enjoying the teardown thus far? Have you had a chance to measure the pistons and cylinders? 95mm or 98mm? Interesting to note that there are 3 different 95mm pistons for the 3.0L motor, depending on the CR that is desired. They can be had with 9:1 CR, 9.5:1 CR or 10:1 CR. Ralph |
Also, the last time the car was fired up was when the Porsche Parade was in Sacramento (must have been around 2000) and that was only to move it from the trailer to the display area. That may be why it is the way it is in appearance on the cylinders and piston tops. |
Ralph, the pistons are 95 mm in diameter. And as for enjoying the tear down so far, well if it were not for the mess and all the cleaning up to do, I think so. I don't particularly enjoy all of the chemical cleaners as well. I have been through about 5 cans of brake cleaner so far. I don't know how people can work on these things all day without getting sick from that aspect of it.
Well, now for today's progress. I worked on the engine for about 9 hours today but most of the time was spent on cleaning and organizing the head, cylinders, cam holders and cam/lifter parts. When I had that under control I got around to removing the pistons. Boy those snap rings that hold the piston pin in place can fly! I thought I was going to loose a couple but found them half way across the garage. I next got around to finally taking the case apart. Once I had all the through bolts out I removed all the periferal nuts. I did make the usual mistake that novices make in forgetting (or failed to see) one of the main bolt nuts inside the case towards the pully end of the engine. I was gently tapping the case to try and get it appart but it wouldn't come. I noticed it separating on the opposite side of the bolt so I figured things out before I did any damage. My wife (who knows how much this thing is worth) came out to visit when I was trying to separate the case halved but went back into the house before it came apart. I sent her into a panic later this evening when I came in and told her I had "cracked the case" when she mistakening thought I had literally cracked it (knowing I have done such things in the past). Well, I am nearly done with the disassembly and will probably leave the rods on the crank when I take every thing to the machinist. I might take them off to look at them first. I haven't decided yet. I still have a lot of cleaning left to do and may take some more pictures of the parts I didn't show before. Below are some pictures of todays progress and close up of the worst bearing surfaces.
Banned
Helidoc,
On the cams, should micropolish them, it is interesting to note that they don't "knife edge" the crank,instead, it is completly rounded.,and they don't "dove tail" the case, but it seems that the lower inner walls of the case are kind of ball pinned, at least they seem to be kind of polished,maybe for good oil runoff? Love those rods.,all those wear patterns on bearings I won't worry about them much, just make shure everything is within spec at the lower end, I have seen much worse without any big issues., cheers,Antonio. |
After doing a couple of engines myself, getting ready to start a Euro 3.0l, and with a 2.7 waiting after the Euro, I am really enjoying this thread! Keep up the great work and keep those pictures coming!! Thanks for sharing helidoc. Glad to see I'm not the only one with an understanding wife... I know it helps! Lou
'76 911 "Moneypenny" daily driver '74 911 "JLo" IROC DE Car '03 CRV, '02 Jeep Grand Cherokee '03 Holiday Rambler Admiral SE, 30ft, 8.1l, 340HP, 455Ft# http://www.nicotra4.hpshare.net/BasketCaseMotorsports/ |
