AirBorne!
3.2 Piston Options, High Compression?
I tore down my engine yesterday, 116,000 well cared for and thoroughly documented -- all receipts back to mile 1 - car and engine. I'm the third owner. I have KS Alusil pistons and cylinders, 95mm, with stock compression of 9.3:1?. We measured the pistons and cylinders and I could use them again if I choose. The tranny shifts just fine and I'm gonna leave it alone. I do not have a limited slip. I'm not opting for gear work as the car is a daily driver, otherwise I'd regear the gearbox or the final drive unit.
I am having cam reprofiling and head port/polish work done to the engine along with a host of other refreshing service items: refresh the rockers, rebuild clutch, you name it.
I have an autothority chip in the car.
The car is my daily driver in good weather. Last year I upgraded the suspension and brakes and did a thorough service of all suspension and drivetrain components. I also back dated the exhaust to pre 1974.
I would like to recoat the cylinders and install JE 10.5 95mm pistons. I am told I will have issues with detonation if I do this as the ROW car I have has a different ECU that the Euro version that came with the 10.3:1 Mahle pistons.
Please provide me with your feedback/recommendations on the following
1. Using the current KS pistons and cylinders. Just rering them and be done with it.
2. Recoating the cylinders and installing new 95mm JE 9.5:1 pistons.
3. Recoating the cylinders and installing new 98mm -- taking displacemnt to 3.4 lts -- JE 9.5:1 pistons.
4. Recoating the cylinders and installing new 95mm JE 10.5:1 pistons.
5. Recoating the cylinders and installing new 98mm-- taking displacemnt to 3.4 lts -- JE10.5:1 pistons.
Or
6. Just fork out the bucks and get a set of Mahle 3.2 liter 95mm 10.3:1 Euro Specs pistons/cylinders.
The cost to do the recoat and the 95mm JE 9.5 or 10.5 pistons is $2,000.
The cost to do the recoat and the 98mm JE 9.5 or 10.5 pistons is about $2,800. (Have to rebore the cylinders to 98mm pistons size before the coating.)
The cost to buy the Mahles 3.2 10.3:1 is about $3,500.
The cost to reuse the existing pistons and cylinders is cheap. Just rings.
Any ideas on power, wear, etc.
Please help.
Wellborn
Old 12-01-2005, 05:49 PM
Jeff Alton's Avatar
Lets see how I do here....
1. You can reuse them but it may be difficult to get the new rings to seat. I have had luck getting the KS stuff honed with the Sunnen 3 step process recommended by KS
2,3,4,5 If you are going to get new pistons and have the cylinders "worked" may as well get 98's and have a 3.4. 10.5 will require twin plugs. Don't be fooled by Mahles inability to state accurate CR numbers. They have a rep for being way overstated....
6+ Mahle makes a great product and many will say that is what you should use. That said, lots of folks have used JE with good results. I have a set 10.5 98's on my shelf now that I will be using this winter. I think you can get the 98's and the cylinders bored/plated for closer to 2k from EBS in Nevada.
Used pistons are already worn to some degree, so I would expect that any new p/c set will outlast what you have now. For ultimate longevity, go with the Mahles....
There is a great thread here on honing, it starts out about nikasil but there is plenty of info about the KS stuff as well on it. Search my user name or "do I need to hone this" and you should find it pretty quickly.
Hope this helps a little
www.turn3autosport.com
Old 12-01-2005, 06:20 PM
Irrationally exuberant
ChrisBennet's Avatar
Re: 3.2 Piston Options, High Compression?
I would question the advisability of "porting and polishing" the heads. According to one source I read (Greg Brown) the stock 3.2 head will flow enough for 300 hp - something you're never going to get near with that restrictive backdated exhaust.
I'm all for building up a motor because it's fun (and life it too short not to have fun) but if you are looking for at HP/$, upgrading to a 3.6 is more cost effective.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 12-01-2005, 07:45 PM
AirBorne!
Thanks for the advice.
I've decided to go with the stock compression JE's at 98mm. EBS says they will bore and recoat my cylinders.
wj
Old 12-02-2005, 10:18 AM
wj
Just a heads up: Make sure you measure the compression. The last 2 sets of "9.5:1" JE's I got CC'd out to 10.5:1. EBS is great but you must still measure everything.
-Chris
Old 12-02-2005, 10:29 AM
