Installing Rods On Crank??
I have looked everywhere and haven't come up with an anwser to if when installing the rods on a crankshaft, should the bearing tabs be facing up or down in the engine case? All I'm doing is using that as a reference to explain if it matters if the rods can be flipped upside down.
This is a 76 2.7 if it matters Thanks |
As I remember it there were no upside dwn to P rods,unlike other eng.
( I had the same Q at one time and Clewit and several others said that) |
Thanks For the info.........
Wayne's book also describes this on Page 124. It's fresh in my mind because I just reassembled the crank this weekend.
Dion |
I looked right over the last paragraph of that section. Will read a little more careful in the furture. Thanks Dion!!!
| All times are GMT -8. The time now is 08:26 PM. |
