Installing Rods On Crank??
I have looked everywhere and haven't come up with an anwser to if when installing the rods on a crankshaft, should the bearing tabs be facing up or down in the engine case? All I'm doing is using that as a reference to explain if it matters if the rods can be flipped upside down.
This is a 76 2.7 if it matters Thanks
Denny 1976 911s targa 1974 widebody G2 style GroupeB 76 www.G2Performanceshop.com Cylinder head recon, case savers,twin plug,rocker arms |
Air Medal or two
As I remember it there were no upside dwn to P rods,unlike other eng.
( I had the same Q at one time and Clewit and several others said that)
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between. |
Thanks For the info.........
Wayne's book also describes this on Page 124. It's fresh in my mind because I just reassembled the crank this weekend.
Dion |
I looked right over the last paragraph of that section. Will read a little more careful in the furture. Thanks Dion!!!
