-   -   rod/chain holder tools needed (http://forums.pelicanparts.com/911-engine-rebuilding-forum/252508-rod-chain-holder-tools-needed.html)
dion914-6 11-21-2005 07:14 PM
Does anyone out there have the rod and chain holder tools that I could borrow or rent for a small fee? They look really easy to make based on Wayne's description in the book, but I only plan on using them once (at least for the foreseeable future), and it seems like a waste of time and metal.
Of course, I'll pay for shipping both ways unless someone in NE Ohio has them handy.
Thanks,
Dion
Rot 911 11-22-2005 07:09 AM
Dion when I did my rebuild I just cut up some stiff cardboard boxes in the shapes needed. Worked just fine.
dion914-6 11-22-2005 05:34 PM
Now that sounds like a much simpler idea! Thanks Kurt.
DionSmileWavy
mb911 11-23-2005 02:05 PM
rubber bands work well for holding rods in place and I used a stainless steel flat sheet bent to fit in the chain housing to hold the chains in place
Mark McClure 11-23-2005 08:04 PM
You don't really need them, I put my case together by holding the case half up, feeding the chain throught the passage and putting the sprocket on it to hold it up. The rods, if placed carefully will sit vertical until you gently place the case down.
Obviously this is the really cheep ass way of doing things and easier with two but works and saves time in finding or making the tools.
Keep posted for next weeks tip on torqueing the heads with a large broom handle and sticky tape!!!!
stevepaa 11-28-2005 08:03 AM
What Mark said, but I had my son hold the chain.
dion914-6 11-28-2005 03:49 PM
Since my Son is 3 years old and easily distracted, that may not work for me very well. :eek:
Mark's method is how I have always put my FV engines together, but I've had enough experiences where the rod fell at the wrong time and made me a very unhappy person. I've always been in a hurry with those engines to 'make the next race'. This time, I have plenty of time to over-engineer the process.
Thanks for the feedback!
Dion
