Less brakes, more gas!
Using used studs?
Have an oppertunity to acquire a full set of used steel and dilivar studs from a low milage engine. Was thinking of using the steel ones to replace my bottom dilivars on the 3.0 I'm now rebuilding.
What do you all think? -Michael
Michael ![]() '82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah '13 Cayenne GTS |
Wer bremst verliert
Im a novice, but when I asked this question I was told teh steel ones are good for reuse...in fact, I have a complete set of steel Pelican-purchased studs I didn't replace the old ones with because the ones in the case were clearly steel replacements in good shape.
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
Buy new ones just to replace the Dilivar. Some people can get pretty brutal removing these from the case. They are not that expensive and if it were me, I'd buy new. Maybe JohnJL would take an offer for his.
Walt 82SC 3.0 81SC 3.6 Last edited by walt; 11-27-2005 at 06:34 AM.. |
You can measure the length of the steel studs and they should be all the same length; if one is longer than the others, it's more than likely over-stretched/heated. I would most definately replace the Dilivar studs.
Charles Navarro President, LN Engineering and Bilt Racing Service http://www.LNengineering.com Home of Nickies, IMS Retrofit, and IMS Solution |
Air Medal or two
the steel ones are not too spendy and do a vital job there.........do you feel lucky??
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between. |
used is fine as long as they were removed with a good stud puller that didn't damage the threads. the 3 roller style stud pullers kill threads, and visegrips do serious damage to threads and shanks too.
