JoeMag's Avatar
Can this cam be fixed?
964 cam from my car ('82 930). This is right side cam #6 intake lobe. Broke a rocker 2nd to last race last year on this and repaced rocker. I was thinking it was from over-rev condition, but now I'm wondering if this may have had something to do with it...
Can this be welded up and reground?
Old 11-26-2005, 06:25 AM
Somatic Negative Optimist
Gunter's Avatar
Camgrinder will help you with this; I believe that it can be welded and reground. But, the hardening????
Questions: Is this a true 964-cam? Or is it an SC-cam ground to a 964-profile:
Could you, please, measure the diameter of the base-circle, and the height of a good lobe in mm?
Base-circle:
Lobe height:
Much appreciated.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 11-26-2005, 08:17 AM
Addicted to Racing
edbaus's Avatar
Gunter,
I know what you are thinking. But this looks deeper than the welding breaking off. Looks like it is on the base circle too, which would not see too much build up at the time of welding.
Also, do you have lobe heights for many cams. I am interested in knowing the lobe height for the 934 cams to see if that is what these that I have are, or if they are something else.
Ed
Check out the parts for sale:
http://www.demonspeedmotorsports.com
PCA National & NASA Instructor, NASA GTS & PCA GT Class Racer.
See my list of current cars in my garage.
Old 11-26-2005, 01:23 PM
camgrinder's Avatar
Its fixable. Its tough to be sure, but it looks like it was a welded cam to begin with?
The welding material ends up at 56-58 RC for hardness. This is close to the original chill cast material hardness. I have found the weld holds up nicely, but the rocker arm pads tend to wear out faster. To put 964 cams in a 930, I prefer to start with new billets instead of welding up used 930 camshafts.
Also, I would not use synthetic oil with welded camshafts.
John Dougherty
Dougherty Racing Cams
Old 11-26-2005, 02:49 PM
Wer bremst verliert
JohnJL's Avatar
Hi John,
Why not use syn with welded cams? Oh, while I'm asking...would a DR20 on SC cams have been welded?
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 11-26-2005, 06:10 PM
camgrinder's Avatar
John, my reason to not use synthetic oil is based on past experiences. Welded cams last longer using dino oils.
Your cams are not welded. Dont worry.
John Dougherty
Old 11-26-2005, 06:28 PM
Gunter's Avatar
Ed: I don't have any cam specs. I don't know 934 cams?? Do you mean 964?
Joe: Please, measure a good lobe with calipers.
Base cyrcle: ? mm
Lobe height: ? mm
I would take Camgrinder's advise on welding and re-using.
Old 11-27-2005, 05:48 AM
JoeMag's Avatar
I'll get those things measured this eve. thx.
Old 11-28-2005, 08:43 AM
JoeMag's Avatar
Gunter -- here ya go.
Base cyrcle: 31.8 mm diameter (this is diameter measured perpendicular to max lobe height)
Lobe height: 8 mm (based on lobe diameter 39.8mm)
...now that doesn't seem right to me since 964 intakes should have have something like 0.46" valve lift. above is 0.315". so i put cam shaft back in cam holder and measured lift with dial indicator and got samething.
what am i missing here? are rocker arms different lengths (from rocker pin to valve and rocker pin to cam surface) at max lift?
...these are web cams so going to call them and ask tomorrow.
Old 11-28-2005, 06:20 PM
camgrinder's Avatar
The 911 rocker arm ratio is on average 1.47-1 to 1.49-1 at full valve lift.
John Dougherty
Old 11-28-2005, 07:18 PM
Gunter's Avatar
Thanks, Joe:
To be sure: Are these measurement from a 964-cam?
True 964-cam, or reground SC-cam?
Old 11-29-2005, 07:11 AM
camgrinder's Avatar
The base circle on Joe's cam is slightly smaller than oem. It should be 32.1 mm The lobe lift is correct for a 964 cam.
John Dougherty
Old 11-29-2005, 08:47 AM
JoeMag's Avatar
Found out they're 930 cams redone to 964 profile. Other cam is fine.
I've read you need to put new rockers in if you reharden cam, and according to Web Cam the aftermarket porsche ones don't last at all. ...where can I get mine resurfaced so I don't need to buy new at $62 EACH!
Old 11-29-2005, 09:11 AM
