Insane Dutchman
Which Oil Pump?
Still very much in parts collection mode....just wondering what oil pump I should use for my engine. Chassis is an '89 Carrera with 6 speed G50 transmission.
Basis is a new '84 case (930 101 108 6R), 74.4mm crankshaft and 98mm p/c's. I'll be using TWM Weber throttle bodies, SSI's (need the heat) and heads from my Euro '79 SC engine. Engine management will be likely TEC3, twin plugged (I am going to use CoP....I hate spark plug wires). Engine displacement will end up as 3.4 litres, tuned for street/touring use
Anyway, I have a new Carrera oil pump (911 107 008 05) and was wondering whether it would be excellent for this engine or should I upgrade to the Turbo oil pump or the 964 oil pump? I tend to be very conservative on things like that, considering this will be the last car I ever rebuild....don't want to have to fix it down the road...
If the concensus is to upgrade, I'll have a new Carrera pump for sale if anyone is interested! Plus of course I will be pulling the factory steel/dilavar studs off the case and replacing them with Raceware stuff...
Opinions?
Dennis
1975 911S with Kremer 3.2
1989 911 Carrera Project Car
Old 12-23-2005, 10:58 AM
resident samsquamch
sand_man's Avatar
Not sure if it needs a case modification or not, but I think the new pump to have is the GT3R. I think Henry Schmidt intalled one recently in Infrared's 965 rebuild.
-jeff
Old 12-23-2005, 12:13 PM
resident samsquamch
sand_man's Avatar
Here ya go:
91 Turbo 3.4 rebuild begins
of course you can't go wrong with the Turbo oil pump, either!
-jeff
Old 12-23-2005, 12:23 PM
Insane Dutchman
Yeah, I have been following that thread....certainly Henry is on my list for the rebuild!
I guess the question is whether I'd actually need to go that extreme (GT3R pump), or whether the current Carrera pump is going to be OK or is the 964 or Turbo pump is needed to ensure reliability for the long term.
Dennis
Old 12-23-2005, 01:59 PM
Dennis:
We use GT3R pumps.
These are less $$$ than Turbo pumps and both are FAR better than 964/993 or Carrera pumps when higher sustained RPM will be realized.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 12-23-2005, 03:27 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Re: Which Oil Pump?
Opinions?
Dennis
The Carrera pump will suffice for your application but if you upgrade I like the GT3R pump very much.
I'll take the Carrera oil pump if the price is right and what's with the Raceware studs. SUPERTEC head studs are far superior in design to every stud on the market.
Of course that is just my slightly biased opinion.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 12-23-2005, 03:48 PM
Insane Dutchman
I suppose I need to ask....Henry, if I send you the Carrera pump and the factory studs, how much money do I have to send to get a GT3R pump and Supertec studs?
My first born male child is at home at the moment (from university engineering) and is available for part compensation...
Dennis
Old 12-23-2005, 10:39 PM
jluetjen's Avatar
BTW - What is the anticipated rev range of the engine? Something being rev'd to 8000 RPM may require a different oil pump strategyg from an engine that is will spend it's whole life between 3000 and 6000 RPM.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 12-24-2005, 05:32 AM
Insane Dutchman
Good point.....car will likely spend 80% of its time toodling along the street in Calgary, with the odd excursion to the highway or longer distance highway travel....
Dennis
Old 12-24-2005, 08:44 AM
jluetjen's Avatar
What sort of camshaft profile are you using?
John
'69 911E
Old 12-24-2005, 12:26 PM
Insane Dutchman
Don't know yet, I have been reading Wayne's book like it was holy and probably will go with his recommendation .... namely S cams. I suspect that I'll hold off that decision until I have more of the parts and closer to the build....
Dennis
Old 12-24-2005, 12:35 PM
Dennis:
If you do use "S" cams, your Carrera pump will be just fine and you don't need to spend any further monies.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 12-24-2005, 01:12 PM
BReyes's Avatar
I would use the carrera pump.
Regards,
Bernard
Old 12-24-2005, 03:36 PM
