-   -   993 block w/964 heads and valve train (http://forums.pelicanparts.com/911-engine-rebuilding-forum/256584-993-block-w-964-heads-valve-train.html)
William Miller 12-16-2005 09:21 PM
I'm looking at an engine with this combination.
I rebuilt my 3.0, but my education doesn't go much beyond that.
Am I right that the 993 cylinder tops have the grove and sealing ring?
What else is good/bad/interesting with this combination?
Thanks!
Bill Verburg 12-17-2005 06:07 AM
from ~'92 up they used the new style head gaskets
generally the 993 heads are considered to be more desireable because of larger ports, lighter valves and valve train, etc. vram heads also have larger valves
the 993 crank is heavier and stronger but the whole rotating recipricating assembly is lighter.
all in all I would rather have a full on 993 than a 964 or 964/993 combo
DW SD 12-20-2005 09:14 AM
Are the combustion chamber volumes equal on 964 and 993 heads? IE compression ratios equivalent?
Bill Verburg 12-20-2005 03:05 PM
Nominal cr is the same
the 993 heads were a big redesign from 964, among the differences are alloy composition and rocker reconfiguration.
