-   -   Head Work - Recomendations (http://forums.pelicanparts.com/911-engine-rebuilding-forum/258737-head-work-recomendations.html)
Boxer 6 01-01-2006 03:29 PM
I'm looking for good head:D work. I will need to get the heads on my 3.2 done soon. Anyone have good experiences that they want to share and what should I budget to get the job done? Does it make sense to twin plug and "plug" those holes in preparation for when I am ready to get the Electromotive system?
Thanks!!
afterburn 549 01-01-2006 06:18 PM
The ans .Is Absolutely YES!!! and dont let anyone say no . Once double plugged you have options dwn the road.......and that cant hurt. Its cheap to do it while apart...so much complicated latter.
As far as head work....almost a religion here..I do my own others say bigger /smaller ports.....for MFI/ Turbo CIS and what knot.....you will have to sort that one out.....I am a firm believer smooth is better then on both ends for a lot of reasons.....(Please dont start a thread war on this pt guys..I know the arguments just stating what I like.....might not be for everyone.)
DonE 01-01-2006 06:52 PM
Depends on how much and what you will do with the car. If its a daily driver and 100% street driving, then add up the costs (machine work, plugs, wires, iginition system, etc) and make your decision. Chances are, dual plug for a street driver is not worth it.
If you are going to build a hot rod with high dome pistons, then its probably a good idea. If you are going to build a track car, then yes.
As for head work, probably the most important point is finding a machine shop that is successful (improving performance) with their headwork program. Tell them what you want to acheive and let them make the recommendation.
eapcpa 01-01-2006 08:47 PM
Lots of good shops, in California. I use German Precision but there are others. It makes sense to do it while it is apart. Call Ted @ German Precision and discuss it with him.
code7rpd 01-01-2006 09:51 PM
I used German Precision for my recent rebuild and Ted is a really nice, helpful, and knowledgable guy.
wilke3169 01-02-2006 04:27 AM
I used EBS. Call Jon he will be more than happy to answer and advise on any question you have.
http://www.ebsracing.com/
ChrisBennet 01-02-2006 05:26 AM
(Anchor) Atlantic Enterprises right next door to you in NJ does all my heads. Excellent quality, very reasonable prices and quick turnaround. AA # is 856-589-5577
-Chris
safe 01-02-2006 06:27 AM
Is it not a waste of money without raising the compression (NA engine)?
I don't see the point of doing the machine work now and then add the expensive stuff later??
cgarr 01-02-2006 08:18 AM
As Safe said if its stock I understand there is no advantage to twin plug, Im going 98mm and 10:5 cr so I did twin plug, so if you raised your cr later everthing would have to come apart anyhow to do so, I would either do the whole enchilada now or dont waste your money on the xtra machining although it is easy to do, they just get a lot of money to do it.
BReyes 01-02-2006 10:01 AM
Sounds like you are on the slippery slope!!!!
Enjoy :)
Regards,
Boxer 6 01-02-2006 10:19 AM
I thinks it's more than just compression. The amount of fuel entering the combustion chamber is the other big factor. The more fuel you can efficiently burn, the more power;) Compression just helps with this process. I just thought by having it done now, it will allow greater flexibility in the future (i.e PMO Carbs). I think the cost of the machine work is relatively inexpensive compared to all the ancillary ignition parts.
Man it's tough to make a Porsche engine any better than it comes from the factory. LOL:D
ChrisBennet 01-02-2006 11:09 AM
It didn't occur to me that you might want to have the heads modified. A 3.2 head is said to flow enough for 300hp in stock form. Unless you are trying to make lots of horsepower I would leave the ports alone.
If you ever need to get the car smogged you will find that going to a factory 3.6 is more cost effective than trying to convert upgrade a 3.2. (BTDT)
-Chris
MBruns 01-02-2006 12:38 PM
3.2 head work
Mark, we can do what ever you need in house at JB Racing, twin plug,street or race valve jobs,clean up port work to full race,Flow bench work etc... we are in Central Fla. take a look at our web site if you like.
Mike Bruns JBRacing.com
Boxer 6 01-02-2006 02:07 PM
Re: 3.2 head work
WOW! That's some shop! That engine on your dyno brings back some fond memory's of being around my NHRA friends. Thanks for the link.
Jeff Jagusch 01-02-2006 03:25 PM
SUPERTEC
Give Henry a call at Supertec, he can help you out with the cylinder heads as well as any other engine issues.
Nice guy too! He has been VERY helpful with my engine projects!
http://www.supertecperformance.com/
Jeff
cstreit 01-02-2006 04:22 PM
Second that. I enjoyed working with Jon
Boxer 6 01-02-2006 04:33 PM
I hear MotorMeister are the best;)
cgarr 01-02-2006 04:40 PM
http://www.iserv.net/~garrett/doggy2.gif you :D
DonE 01-02-2006 06:28 PM
Actually, the two most important components for twin plugging are compression and displacement. The higher the compression, the harder it is to light the fire. Also, the larger the volume to light, the more the benefit to have multiple spark sources. Then add an obstruction like high piston domes, low AFR's, timing, spark plug placement and so on, the argument for twin plug improves.
In any event, talk to an expert for their input on your application. I chose JB Racing because of their proven race program and their willingness to take the time to talk to me about my options.
I think you can really improve an earlier porsche motor if you plan it out carefully. There are quite a few things you can do economically to wake these motors up. At the same time, Chris B has good advice for big power.
anh911 01-02-2006 06:45 PM
There's no reason to add more fuel unless you have more effective compression. That means either you increase the compression ratio or force induction via turbo or supercharger. For any given displacement/HP engine the amount of fuel required is known, you can't make more HP by adding more fuel only. If you do inrease ECR by some means then twin plug can be a plus. Beyond a certain CR (subject of many debates here) its a must. On Porsche motors, the theory is that it has to do with some inherent inefficiency regarding flame front/travel in the combustion chamber due mainly to the less than optimal spark plug location.
Chris is correct, the 3.2 heads flow plenty out of the box.
Boxer 6 01-02-2006 07:01 PM
That's all good information guys. Thanks! Like I said in my previous post, that's some shop at JB Racing.
