Head Work - Recomendations
I'm looking for good head
work. I will need to get the heads on my 3.2 done soon. Anyone have good experiences that they want to share and what should I budget to get the job done? Does it make sense to twin plug and "plug" those holes in preparation for when I am ready to get the Electromotive system?Thanks!!
Mark 1987 Carrera 2018 GMC Sierra Denali 2500 Duramax 2012 Harley Davidson FLHX Street Glide |
Air Medal or two
The ans .Is Absolutely YES!!! and dont let anyone say no . Once double plugged you have options dwn the road.......and that cant hurt. Its cheap to do it while apart...so much complicated latter.
As far as head work....almost a religion here..I do my own others say bigger /smaller ports.....for MFI/ Turbo CIS and what knot.....you will have to sort that one out.....I am a firm believer smooth is better then on both ends for a lot of reasons.....(Please dont start a thread war on this pt guys..I know the arguments just stating what I like.....might not be for everyone.)
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
Wo ist die Rennstrecke?
Depends on how much and what you will do with the car. If its a daily driver and 100% street driving, then add up the costs (machine work, plugs, wires, iginition system, etc) and make your decision. Chances are, dual plug for a street driver is not worth it.
If you are going to build a hot rod with high dome pistons, then its probably a good idea. If you are going to build a track car, then yes. As for head work, probably the most important point is finding a machine shop that is successful (improving performance) with their headwork program. Tell them what you want to acheive and let them make the recommendation. |
Loose nut bhind the wheel
Lots of good shops, in California. I use German Precision but there are others. It makes sense to do it while it is apart. Call Ted @ German Precision and discuss it with him.
Ed 1970 911S Targa 2.7RS MFI dual plug 10.5:1 1974 260Z SCCA ITS 1998 M3 Last edited by eapcpa; 01-01-2006 at 08:52 PM.. |
I used German Precision for my recent rebuild and Ted is a really nice, helpful, and knowledgable guy.
I used EBS. Call Jon he will be more than happy to answer and advise on any question you have.
http://www.ebsracing.com/
Kevin '79 Coupe |
Irrationally exuberant
(Anchor) Atlantic Enterprises right next door to you in NJ does all my heads. Excellent quality, very reasonable prices and quick turnaround. AA # is 856-589-5577
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
I don't see the point of doing the machine work now and then add the expensive stuff later??
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
abit off center
As Safe said if its stock I understand there is no advantage to twin plug, Im going 98mm and 10:5 cr so I did twin plug, so if you raised your cr later everthing would have to come apart anyhow to do so, I would either do the whole enchilada now or dont waste your money on the xtra machining although it is easy to do, they just get a lot of money to do it.
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Sounds like you are on the slippery slope!!!!
Enjoy ![]() Regards,
Bernard |
I thinks it's more than just compression. The amount of fuel entering the combustion chamber is the other big factor. The more fuel you can efficiently burn, the more power
Compression just helps with this process. I just thought by having it done now, it will allow greater flexibility in the future (i.e PMO Carbs). I think the cost of the machine work is relatively inexpensive compared to all the ancillary ignition parts.Man it's tough to make a Porsche engine any better than it comes from the factory. LOL
It didn't occur to me that you might want to have the heads modified. A 3.2 head is said to flow enough for 300hp in stock form. Unless you are trying to make lots of horsepower I would leave the ports alone.
If you ever need to get the car smogged you will find that going to a factory 3.6 is more cost effective than trying to convert upgrade a 3.2. (BTDT) -Chris
3.2 head work
Mark, we can do what ever you need in house at JB Racing, twin plug,street or race valve jobs,clean up port work to full race,Flow bench work etc... we are in Central Fla. take a look at our web site if you like.
Mike Bruns JBRacing.com |
Re: 3.2 head work
SUPERTEC
Give Henry a call at Supertec, he can help you out with the cylinder heads as well as any other engine issues.
Nice guy too! He has been VERY helpful with my engine projects! http://www.supertecperformance.com/ Jeff |
Super Moderator
Second that. I enjoyed working with Jon
I hear MotorMeister are the best
abit off center
you
In any event, talk to an expert for their input on your application. I chose JB Racing because of their proven race program and their willingness to take the time to talk to me about my options. I think you can really improve an earlier porsche motor if you plan it out carefully. There are quite a few things you can do economically to wake these motors up. At the same time, Chris B has good advice for big power. |
Chris is correct, the 3.2 heads flow plenty out of the box.
anh911 '94 Dakota - Meh '98 Moto Guzzi - woo hoo 911; XJS; Islander 36; All Sold '97 YZF1000RJ - Totaled (Not by me) |
