adomakin's Avatar
so do i need to buy a mechanical chain tensioner for my rebuild?
or is there another way?
Andy
1980 SC soon to be big hp 3.3t powered 73RSR Replica (well, I'm keeping the engine but everything else is going )
Old 01-11-2006, 11:46 AM
No. If you're referring to the cam timing procedure, then you can use a "C" clamp on the left side. The right side is trickier. A mechanical tensioner is perfect for the that side; however, you can get around it. I used a bolt and a thread coupler to tension the right side idler arm. The thread coupler wedged into the bottom of the chain case with the head of the bolt pressing against the idler arm. By "unscrewing" the bolt from the coupler, I could tension the chain adequately.
Regards,
Ed Cavalier
Old 01-12-2006, 10:49 AM
adomakin's Avatar
nice tip Ed, thanks.
Andy
Old 01-12-2006, 11:15 AM
