Send a message via AIM to domtoni
Leaky 2.0 1969 E Motor
My motor is leaking between the two block halves and forward on the right hand bank head to block.
Can we just shoot some new Locktite sealant between the two block halves or does the engine have to come apart?
I suspect the head has to come off to fix that.
Dom
dom toni 911E
Old 01-12-2006, 09:43 AM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
Dom,
"shooting new loctite" won't do you any good. Depending on how bad the leak is the engine either needs to come apart ($$$$) or you need to learn to live with the leak.
Cheers,
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 01-12-2006, 10:26 AM
Dom:
Sorry, pal.
To stop the leak(s), its going to have to come apart as Ingo said.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 01-12-2006, 11:03 AM
3 restos WIP = psycho
kenikh's Avatar
There's always stop-leak oil additive.
JK.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 01-12-2006, 11:40 AM
Guys,
Oil leaks are too big to use a stop leak. I will live with the leaks.
Ciao
Dom
dom toni 911E
Old 01-13-2006, 01:26 PM
kenikh's Avatar
I was joking.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 01-13-2006, 02:10 PM
Hello, Dom.
If the leak is really between the halves, it is worth checking the studs are not stripped.
this is a feasible fix in situ, but of course once a leak starts the case will be bent and may need skimming to correct..
Anothe stud which very often strips is the long one by the Int shaft bearing..there is IIRC a fix for this in situ but only Crispin Manners knows how!
Kind regards
Old 01-13-2006, 02:16 PM
