964 cam timing in my 930
does anyone have the cam timing specs for 964 cams in a 930? does it differ depending on your requirements from the engine and if so, how?
Andy 1980 SC soon to be big hp 3.3t powered 73RSR Replica (well, I'm keeping the engine but everything else is going )
Hi Andy,
I was given 1.68mm for my 3 litre turbo, but I've seen specs between 1.50 mm & 1.70 mm Cheers
PaulM 1977 930 1993 Nissan GT-IR 2000 Subaru WRX |
Wo ist die Rennstrecke?
1.26mm from Dougherty Racing Cams
cheers Paul. Don, thanks for the spec. i knew i'd seen it somewhere recently (DRCamshafts!)
