stretching rods to raise CR
I have a 2.7 motor that I'm rebuilding. I was wondering if there would be concerns about lengthening the rods with eccentric rebushing. I was thinking of using 2.7 RS p/c and lengthening by .020 to raise the CR to about 9:1. I was also planning on using solex cams. Or would it be better to go with JE pistons. Planned to be driven on the street. Thanks. Paul.
Old 07-25-2009, 07:15 PM
Try not, Do or Do not
Henry Schmidt's Avatar
although there are beniefits to a longer connecting rods on most 911 engines I would choose to replace the pistons if budget was not an issue.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 07-26-2009, 02:02 PM
Thanks Henry for your advice. Are JE pistons as durable as Mahle? I was wondering because of the recommeded greater running clearance for the JE's. Paul.
Old 07-27-2009, 06:22 PM
3 restos WIP = psycho
kenikh's Avatar
Lots of info on this if you search. JEs are VERY durable these days and very comparable to Mahles.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 07-28-2009, 07:53 AM
