930 Cylinder air guide help
My '78 3.3 cyl. air guides are different than a replacement set I bought(used) as I had one rusted out and no cover plates? In comparing; the ones that were on the engine are all "closed" at the base and the center ones are cut different? Does some have a picture of what I should have? Should I install cover plates. These are stock (not fully finned) cylinders.
TIA
KM
Old 01-16-2006, 08:25 AM
78P930's Avatar
Ken, Is this what you are talking about?http://www.pelicanparts.com/techarticles/911_engine_tin_cooling/911_engine_tin_cooling.htm
10 Ford Raptor
86 930
Old 01-16-2006, 11:56 AM
MBEngineering's Avatar
HI Ken the 3.3 turbo has cylinder tin work diffrent to the sc, and no cover plate over the top of the cyliner's, you will require tin work from a 3.3 only, look on the pet parts manual and check part No's.
regards mike
Regards mike
1983 911 SC sport, 1982 mini city
Old 01-16-2006, 12:43 PM
Thanks 78P930, I know about the mod.. what I'm confused about is that the guides that were on my engine are different than the picture i.e. closed on the ends on the bottom and staggared cut on the bottom and there was no top plate. I bought a set of used that look like the picture I thought they were all the same until my mechanic asked if the set I bought was correct for the turbo eng.? So now I'm trying to find out what I should have?
Old 01-16-2006, 12:56 PM
Thanks Mike... appreciate the info... I figured they are different... But because of other things I found on the engine they too could have been wrong! Didn't catch that the parts manual shows a 01 revision to the part number for '78-'89 T and doesn't list a cover plate for '78 tubo. But does for the '76-77? Well all except 1 center can be refinished maybe some one has one?
thanks again
Old 01-17-2006, 11:59 AM
HI if you get stuck PM me and i will pick up what you require nex time i am down the brakers yard, as i know thay have a engine striped.
regards mike
Regards mike
Old 01-17-2006, 02:54 PM
justin's Avatar
Um, Ken, is it running yet???
LOL
Texas hosts the 928 Owner’s Club OCIC in 2009
www.928ocicdfw09.com
1980 928 5 speed and a few mods..........
928 OC member
PCA member
Old 01-17-2006, 06:13 PM
vichang4's Avatar
Here are a few pictures of the tin on my 87 911 turbo. These are on 3.4 mahle cylinders.
I hope this helps
Victor Toce
2000 Boxster S w/
Tequipment exhaust
1993 Spec Miata
87 911 turbo - sold
3.4 RUF pistons and cylinders
Euro CIS head
Old 01-17-2006, 06:52 PM
air guides
Thanks guys, Victor, the pictures confim that what I had on the engine (boxed bottom) is correct. Cleaned them up for refinish and only 1 of the center ones need to be replaced ..might try to make a new one?... Mike if you run across one in the near future give me a shout @ kcmartin@joimail.com
thanks
KM
Old 01-20-2006, 06:56 AM
Victor.. no cover plates ...right?
Old 01-20-2006, 07:08 AM
