I'm interested on ideas to gain a few extra HP without investing a small fortune (Ideally proven on a dyno or such). I have a 1971 911 S, 2.2, with approx 180hp. It's stock except for a K&N air filter and some nice plug leads. I drive it mostly at DE events....Seems it's already fairly well tuned from the factory but can I get more ??
Thanks for your ideas ! |
Crusty Conservative
No easy mods to that engine, alas. Sport muffler and a good solid state ignition maybe.
Try making the car lighter, the suspension more raceworthy, and the brakes better. Take a high speed driving course.
Bill 69 911 T Targa, 2.4E w/carbs (1985-2001) 70 911 S Coupe, 2nd owner (1989- 2015) 73 911 T Targa, 3.2 Motronic (2001- ) |
3 restos WIP = psycho
HP is directly proportional to $$$. The cheapest way to increase net HP is to gut your car of every unneeded interior component. You may not like driving the car, but that extra speed will be free.
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
PRO Motorsports
The factory sport muffler, with the two tips coming straight out the back below the license plate panel, is good for 15HP.
That's the cheapest you're going to get. Sounds pretty nice too. Not too obnoxiously loud, but a real sweet sound. I've seen the dyno proof, and Bruce Anderson has stated the same thing in his 911 Performance Handbook, with dyno sheets to prove it.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
Air Medal or two
Throw out the spare and jack.Get rid of the stock batt and put in a PC 680. This will raise eyebrows -throw the stock muffler out and all related crap put in a generic "turbo" muffler (cut to fit) add a tail pipe(s).....Now your movin
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between. |
PRO Motorsports
The factory early sport muffler is the shiznit on an MFI car.
One thing I have been wondering about.
Are there any mufflers for the post -74 exhaust that will gain a few HP?
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
Crusty Conservative
You can backdate the heat exchangers or go to SSI's, then add a 2 in 2 out Sport Muffler. That will gain you some HP, and AFAIK will work fine with CIS systems and retain your heating.
For example removing the pre-muffler (on pre cat cars), such as my euro -77 or getting more "free flowing" muffler.
Re: Cheap HP
There are very few if any mufflers that will "improve upon" the HP vs. noise compromise of the factory muffler. If the muffler does end up changing the engine's performance by much, you'll find that the 3D space cam (aka: injection map) will no longer be synchronized with the engine's performance and you'll wind up with issues like the flat spot mentioned above. Changing the air filter won't improve the performance. You can prove this to yourself just by removing the filter all together and taking a quick spin down the road (avoiding dusty areas BTW). You'll most likely discover that you can't even notice the difference. You're best bet to improve the car's performance will be to remove weight, and give the driver more experience (by driving it!).
John '69 911E "It's a poor craftsman who blames their tools" -- Unknown "Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman |
I lay awake nights imagining variable valve timing on a 911. 'T' cam torque down low and 906 HP on top. A two liter 911 would give an S2000 a serious run for the money in that case.
Thanks for all your responses, I'm already off down the lightening track so good advice here. Refererring to the chart in Andersons Book (pg 141) for the 2.4 S Stock v Sport muffler does anybody have a similar chart showing benifits/otherwise for a 2.2 ??? I must admit I'm slightly sceptical about this data - max power at 5500rpm on a 2.4 S ? - seems about 1000 rpm shy ?
does the early factory sport type muffler increase power for early carburetted cars as well?
or is any gain specific to the MFI induction? thanks in advance nathan |
Crusty Conservative
http://www.early911sregistry.org/forum/showthread.php?t=4752&page=3&highlight=k%26n Brooke
Brooke 1969 911 ST 2.8SS EFI ITB (Irish Green), 1974 911 3.6 ITB (Black) 1952 MG TD with F20C |
Crusty Conservative
I agree with rswannabe.
My experience is that the 10 to 15 hp increase is optimistic at best on an early engine that already has free flowing heat exchangers. The data may have become somewhat muddled over the years as mid year cars were backdated and a sport muffler was attached...
