3.0l pistons?
I wounder if porsche had forged pistons on 3.0l sc engines (78-80)
Old 01-15-2006, 07:41 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Yes, all Nikasil cylinders came with forged pistons.
They also had cast pistons in Alusil cylinders.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 01-16-2006, 06:42 AM
Are the orginal pistons solid constuction? i'm using a 3,0lsc that is turbocharged. any experiece with how mutch power\ they can handle??
-92 964 C4
- 79 930 "ruf" 380whp, K27, andial IC, Headers, electromotive hpv.
- 88 "gt2" (project)
Old 01-16-2006, 08:35 AM
The forged pistons are very strong.
No problem at 400 + hp.
Henry Schmidt
Ph: 760-728-3062
Old 01-16-2006, 09:26 AM
thanks
-92 964 C4
Old 01-16-2006, 10:27 AM
what engines came with alusil\nikasil in pre -89??
-92 964 C4
Old 01-17-2006, 09:26 PM
Some 2.7 (90mm), 3.0(95mm) and even 3.2 (95mm)
Henry Schmidt
Ph: 760-728-3062
Old 01-18-2006, 05:42 AM
nikasil or alusil??
-92 964 C4
Old 01-18-2006, 05:56 AM
All three cylinder types [Alusil KS , Silimal and Nikasil Mahle] were used in 2.7s then Alusil and Nikasil were used in 3.0s and 3.2.
What are you really trying to figure out?
Henry Schmidt
Ph: 760-728-3062
Old 01-18-2006, 06:21 AM
Just trying to find out if I have forged piston or cast.....
Have a -80sc from europe. Can I tell them apart whithout disambling the engine? Or do I need the number on the piston??
-92 964 C4
Old 01-18-2006, 09:34 AM
what about chassie number or engine number? does that tell anyting??
-92 964 C4
Old 01-18-2006, 10:01 AM
