andrew15's Avatar
Unhappy REALLY stuck cylinders
Ok - I've taken apart many a 911 engine in my time, but today I hit a wall (and my thumb with a slipped wrench, but thats another story). The cylinders just don't want to come out. They are nikasil cylinders in a magnesium block. The crank rotates fine and the pistons move, but there is NO unseating cylinder-wise. This is afterrotating crank, pulling, gentle tapping with a rubber mallet, pulling, etc
Any helpful ideas floating out there? The sooner I can get this engine torn down completely, the sooner the heads go off to Henry for a rebuild.
Thanks,
Andrew M
1970 911E - track / weekend car
1970 911S - under restoration
1986 930 Slant Nose - fun car
Current used parts for sale
Old 01-29-2006, 04:49 PM
Old Member
Andrew
I use a large rubber mallet, but not gently.
Clifton Brown
https://www.mancalamarketing.com
Old 01-29-2006, 06:49 PM
Air Medal or two
afterburn 549's Avatar
more pwr scotty !!!....maybe piston at bdc blocks of wood both sides ,pry bar both sides a buddy to rotate eng to tdc as you pry,- all in unison.....at least might get cyl off the case for more inspection, Truly should not be too difficult
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between
Old 01-29-2006, 08:35 PM
andrew15's Avatar
I'm starting to think that the cold temp had something o do with it. Even though it was warm for winter, the garage was -3c. It's supposed to be warmer tomorrow, so I'll try the big rubber mallet & wood blocks then.
Regards,
Andrew M
Old 01-29-2006, 08:41 PM
Air Medal or two
some are stubborn...just need more discipline.
Old 01-29-2006, 08:54 PM
adomakin's Avatar
you could play some heat round the spiggot holes as you tap the barrels with a rubber mallet. don't worry about the case-it will pull the heat away real quick so something like mapp gas will be good.
Andy
1980 SC soon to be big hp 3.3t powered 73RSR Replica (well, I'm keeping the engine but everything else is going )
Old 01-30-2006, 11:58 AM
big rubber (not plastic) hammer. two bips down, two bips up, toward the bottom where the fins are short to avoid breakage. repeat as needed. pull outward as you hit it. then rebore the spigots so they go back in nicely. typical 2.7.
206 637 4071
Old 01-30-2006, 02:10 PM
