-   -   Need help figuring up piston cc's needed (http://forums.pelicanparts.com/911-engine-rebuilding-forum/262119-need-help-figuring-up-piston-ccs-needed.html)
edbaus 01-21-2006 11:05 AM
Looking to make some 2.2L pistons for a turbo.
What I need to know is what the dome cc's are supposed to be to give me about 7.3:1 compression ratio.
What I have heard is that the heads (2.2L twin plugged) are approx. 69cc's
The piston skirt gap is 1 mm.
If this is correct, then it looks like I need a 9cc dome.
This seems odd. I would have thought I needed a dish.
Anyone see a problem with my calculations?
Ed
cgarr 01-21-2006 11:13 AM
I think you might plug in your numbers here and come up with the dome you need? might have to convert some to mm
http://www.csgnetwork.com/compcalc.html
kstylianos 01-21-2006 12:01 PM
Assuming bore of 84mm, stroke of 66mm, deck height height of 1mm, and your given head cc of 69: Piston dome needs to be 16.5cc for 7.30:1 CR
Changing deck height to 1.25mm: Piston dome needs to be 18cc for ~7.31:1 CR
I can send you the .xls file to make these calculations easier.
edbaus 01-21-2006 01:14 PM
Does anyone have a set of 2.2 or 2.4L heads that they can cc for me. Mine are out and I want to make sure that 69 is right.
Ed
2.7RACER 01-21-2006 07:49 PM
Ed,
I came up with the same as Charlie, 16.4 dome with a 1mm deck height.
Bruce Anderson says "the 2.2 to 2.7 heads are in the 68mm range"
edbaus 01-22-2006 11:11 AM
Ed
