Addicted to Racing
edbaus's Avatar
Need help figuring up piston cc's needed
Looking to make some 2.2L pistons for a turbo.
What I need to know is what the dome cc's are supposed to be to give me about 7.3:1 compression ratio.
What I have heard is that the heads (2.2L twin plugged) are approx. 69cc's
The piston skirt gap is 1 mm.
If this is correct, then it looks like I need a 9cc dome.
This seems odd. I would have thought I needed a dish.
Anyone see a problem with my calculations?
Ed
Old 01-21-2006, 11:05 AM
abit off center
cgarr's Avatar
I think you might plug in your numbers here and come up with the dome you need? might have to convert some to mm
http://www.csgnetwork.com/compcalc.html
______________________
Craig
G2Performance
Old 01-21-2006, 11:13 AM
kstylianos's Avatar
Send a message via Yahoo to kstylianos
Assuming bore of 84mm, stroke of 66mm, deck height height of 1mm, and your given head cc of 69: Piston dome needs to be 16.5cc for 7.30:1 CR
Changing deck height to 1.25mm: Piston dome needs to be 18cc for ~7.31:1 CR
I can send you the .xls file to make these calculations easier.
Charlie Stylianos
1982 SC Targa
www.Dorkiphus.com - (The Land of the NoVA/DC/MD Porschephiles)
Old 01-21-2006, 12:01 PM
Addicted to Racing
edbaus's Avatar
Does anyone have a set of 2.2 or 2.4L heads that they can cc for me. Mine are out and I want to make sure that 69 is right.
Ed
Check out the parts for sale:
http://www.demonspeedmotorsports.com
PCA National & NASA Instructor, NASA GTS & PCA GT Class Racer.
See my list of current cars in my garage.
Old 01-21-2006, 01:14 PM
Ed,
I came up with the same as Charlie, 16.4 dome with a 1mm deck height.
Bruce Anderson says "the 2.2 to 2.7 heads are in the 68mm range"
DOUG
'76 911S 2.7, webers, solex cams, JE pistons, '74 exhaust, 23 & 28 torsion bars, 930 calipers & rotors, Hoosiers on 8's & 9's.
'85 911 Carrera, stock, just painted, Orient Red
Old 01-21-2006, 07:49 PM
Addicted to Racing
edbaus's Avatar
Ed
Old 01-22-2006, 11:11 AM
