-   -   How to rebuild turbo scavange pump?? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/263906-how-rebuild-turbo-scavange-pump.html)
JoeMag 01-31-2006 10:10 AM
Has anyone rebuilt one of these? Any tricks to it or pitfalls? Since I got the engine apart figure I should look into this, plus I think it may be leaking a little around the shaft.
...did search and couldn't find anything.
--Joe
afterburn 549 01-31-2006 05:02 PM
I think you buy new........You might ask Henry S. or John walker
PJMARKOW 02-02-2006 12:04 AM
There were seals for the pump in my gasket set when I rebuilt my 1977 930. I pressed out the pin (that is used to engage the allen bolts on the end of the cam) and pulled it apart and replaced the seals. It's a good idea to keep the gears in the same relationship to each other when you reassemble, as they would have worn together over time.
Cheers
