JoeMag's Avatar
How to rebuild turbo scavange pump??
Has anyone rebuilt one of these? Any tricks to it or pitfalls? Since I got the engine apart figure I should look into this, plus I think it may be leaking a little around the shaft.
...did search and couldn't find anything.
--Joe
Old 01-31-2006, 10:10 AM
Air Medal or two
afterburn 549's Avatar
I think you buy new........You might ask Henry S. or John walker
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between
Old 01-31-2006, 05:02 PM
PJMARKOW's Avatar
There were seals for the pump in my gasket set when I rebuilt my 1977 930. I pressed out the pin (that is used to engage the allen bolts on the end of the cam) and pulled it apart and replaced the seals. It's a good idea to keep the gears in the same relationship to each other when you reassemble, as they would have worn together over time.
Cheers
PaulM
1977 930
1993 Nissan GT-IR
2000 Subaru WRX
Old 02-02-2006, 12:04 AM
