-   -   Engine test run stand (http://forums.pelicanparts.com/911-engine-rebuilding-forum/263955-engine-test-run-stand.html)
kenrinc 01-31-2006 03:38 PM
I like the test run stand that Wayne shows in the book. Wayne you got anymore info on that guy? Looks simple to make. I'm considering using it to break in my 2.0 in order to make sure everything works before I put it back in.
Ken-
ANTONIO 01-31-2006 05:19 PM
Ken,
IMHO is not worth it, years ago I built my own and I use it only once,mostly was for bling bling the engine. It will take you more time to set the engine in the stand and actually start it,than using your own chassis as a stand,cheers,Antonio.
