Engine test run stand
I like the test run stand that Wayne shows in the book. Wayne you got anymore info on that guy? Looks simple to make. I'm considering using it to break in my 2.0 in order to make sure everything works before I put it back in.
Thanks Ken- |
Banned
Ken,
IMHO is not worth it, years ago I built my own and I use it only once,mostly was for bling bling the engine. It will take you more time to set the engine in the stand and actually start it,than using your own chassis as a stand,cheers,Antonio. |
