-   -   Valve clearance question (http://forums.pelicanparts.com/911-engine-rebuilding-forum/264134-valve-clearance-question.html)
billd 02-01-2006 01:24 PM
I'm planning to run Solex cams on my 2.7L using the Mahle 8.5:1 Euro Pistons.
Has anyone done this? Does anyone know if I will have clearance issues?
Thanks, Bill
Henry Schmidt 02-01-2006 07:19 PM
That is one of my favorate engine for a 914-6.
I build my 6 that way 8 years ago. My 6 used carbs but we've also built the engine with MFI and the customers couldn't be happies.
Get street performance and a real kick to drive on mountain roads.
http://forums.pelicanparts.com/911-engine-rebuilding-forum/246257-do-yourself-pay-pro.html
http://forums.pelicanparts.com/911-engine-rebuilding-forum/190744-supertec-project-finished.html
http://forums.pelicanparts.com/uploa...1138850224.jpg http://forums.pelicanparts.com/uploa...1138850314.jpg
billd 02-01-2006 10:50 PM
Thanks for the reply Henry. My engine is almost the same except I used 2.7 "S" heads and just left the ports at 35 rather than opening them up to 36.
I'm planning to run a set of 40mm Weber IDA carbs on this. Any suggestion on Venturis and Jets?
This is for my 914/6 conversion.
