Smoking engine
My 2.4 911S engine smokes bad.
Not at start up but when warm. Compression is 170 on all cylinders. What causes that? Valve seals? thanks, harold |
Hmmm wide open anser....evrything from oil leaks to the out side to oil leaks in the inside.....oil on the exhaust ?? worn rings and yes worn guides
Smoke
It helps to know the color of the smoke...
White=Oil Black=Fuel |
Blue smoke, after about 3 minutes of engine running, worse when I rev the engine. No outside leaks.
Will check the intake valve seal and guide. thanks |
probably guides....
What oil are you using & weight? What is the warm tank level reading?
Out the tail pipe? At least a top end rebuild.
Otherwise if it is something like a line you with help of this forum can fix it. Good luck. |
| All times are GMT -8. The time now is 05:38 AM. |
