Hbrand
hbrand's Avatar
Smoking engine
My 2.4 911S engine smokes bad.
Not at start up but when warm. Compression is 170 on all cylinders.
What causes that? Valve seals?
thanks, harold
Cheers
1982 Porsche 911SC Euro
1969 Mercedes 280SL
1956 Austin Healey 3x
Old 02-02-2006, 12:17 PM
Air Medal or two
afterburn 549's Avatar
Hmmm wide open anser....evrything from oil leaks to the out side to oil leaks in the inside.....oil on the exhaust ?? worn rings and yes worn guides
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between
Old 02-02-2006, 09:58 PM
78P930's Avatar
Smoke
It helps to know the color of the smoke...
White=Oil
Black=Fuel
Old 02-03-2006, 09:11 AM
Hbrand
hbrand's Avatar
Blue smoke, after about 3 minutes of engine running, worse when I rev the engine. No outside leaks.
Will check the intake valve seal and guide.
thanks
Cheers
1969 Mercedes 280SL
Old 02-03-2006, 01:31 PM
Air Medal or two
probably guides....
Old 02-03-2006, 05:30 PM
Crusty Conservative
silverc4s's Avatar
What oil are you using & weight? What is the warm tank level reading?
Bill
69 911 T Targa, 2.4E w/carbs (1985-2001)
70 911 S Coupe, 2nd owner (1989- 2015)
73 911 T Targa, 3.2 Motronic (2001- )
Old 02-04-2006, 09:38 AM
BReyes's Avatar
Out the tail pipe? At least a top end rebuild.
Otherwise if it is something like a line you with help of this forum can fix it.
Good luck.
Bernard
Old 02-04-2006, 08:24 PM
