Friends of Warren
GT3 oil pump vs 993 stock
I am considering upgrading the 993 stock pump with a GT3 oil pump...
Would it be useful on a street/DE car or is just a waste of money? It should have an extra pick up point which enhances scavenging. Output should be the same and it should be made of iron ald aluminum instead of mgnesium. What do the experts here think? Thank you! |
I bought one in November thinking that the price may be more reasonable now while they're plentifully. The one thing that surprised me was how it freewheels for a few seconds after spinning it by hand. It's still dry though no oil to slow it down.
I think you will have to clearance the case to...
75 911S Coupe 3.4 Twin Plug - ITB - MegaSquirt 84 Carrera Coupe M491 |
Alter Ego Racing
I believe it has an additional stage on it (at least compared to the early one its replacing on my car).
For a race car its great as it allows for the proper pressure when using large diameter lines.
International GT Champion; Porsche GT3 Cup Trophy Champion; Klub Sport Challenge Champion; Rolex Vintage Endurance Series Champion; PCA Club Racing Champion; National Vintage Racing Champion |
GT3 RS pump (83 liters per minute, scavenge side 135 liters per minute).
GT1 pump, also used on the Turbo LeMans GT and certain other race cars (83 liters per minute, scavenge side 160 liters per minute) GT3RS pump the 964 is mg,pressure side = 65l/min, scavange side = 1.84 x pressure side the 930 3.3 is al/cast iron,pressure side = 100 l/min(best I remember) and is 8mm longer than the 964 pump ie needs a different shaft 3.3 pump 964/993pump 993 pump 993 upper GT3RS lower If you are replacing the pump any way yes, otherwise the 993 pump is pretty good.
Friends of Warren
No I am not replacing the pump. But in building the motor from schratch one gets to choose...
Thanks for the feedback... |
It becomes a question of where do you stop, why not use a GT3RS crank too?
Friends of Warren
Good point... I'll stick with the 993 one then.
Bill,
I see people with 3.3L's replacing their stock pump with a GT3 RS pump. From your pictures and oil volumes it looks like the pressure stage is shortened to make room for the second scavenge stage, thus increasing scavenging, but decreasing pressure side volume. Is that a good idea? Win
1986 911 Turbo 3.3L, K27HFS, Tial 46mm, TurboKraft Intercooler, 964 Cams, Monty Muffler, MS3Pro Evo, M&W Ignition, Zietronix WBO2 Data Logger, Wevo shifter, coupler and motor mounts. |
There's no doubt in my mind that the GT3RS pump is a more capable pump , but do you need it?
The 930 and 964 pumps are pretty darn nice pieces too. For a 24hr of Lemans or Daytona motor sure, but why replace a perfectly serviceable item, the list is long and expensive as to what can and should be up graded. The decision that is up to each of us individually is, where do you draw the line for our use?
What is a GT3RS pump worth, see my thread.
I have one with only 8,000 Kms on it. T hanks, Bavaria
Bavaria911 1970 911T w/ 2.4S 1971 911T Targa w/ 2.2 RG Member # 818 |
They can be purchased new for 758.37 from,
http://mindovermotorsports.zoovy.com/product/99610700793 Supertec has them in stock for I believe 850.00
![]() 914 6 Turbo twinplug 3.12 87 924S Lexus SC400 Lexus LS400 |
I was thinking about doing the same thing. I was going to increase the piston squirters to the 964 and put in the GT3 pump. But after speaking with Walt at Competition Engineering and Henry at Supertec he told me that my SC pump was plenty good unless I was going to live on the race track. It will only buy you piece of mind nothing else. And it won’t give you any extra HP. So I opted against it.
Here are the Specs on my motor. My engine is going to be based off of a 911 3.0 case: Shuffle pined & boat-tailed 102 P&C’s mooned 10.8.1 CR 70.4 mm crank Pauter rods Heads are ported and twin plugged by Heritage Motorcars in FL & Custom Inconel and Titanium valve train made by them reducing weight by 281.96 grams Custom Cams made my Heritage Motorcars for heads above. Light flywheel & Pressure plate. Entire rotating assembly balanced to 8500 RPM with in 1 gram Jenvey ITB’s with aftermarket ECU
Kenneth Silver 81' Targa |
Well - OK...someone can save $300. I'll let it got for $450.
Thanks, Bavaria911
Banned
For street and straight racing acceleration nothing beats the stock 930 pump,it has the hightest volume in the press side.,cheers,Antonio.
Banned
Bavaria911 I sent you a pm,cheers,Antonio.
Antonio,
Looks like I'll keep the pump. Thanks, Bavaria911
Banned
Scott,
No problem,cheers,Antonio. |
