strep's Avatar
Question Check this please
I pulled the fuel injection. This is what I found. Why is there oil in this area. This is the number 6 plug I believe. It has always been fouled. I pulled the motor cause it has over time started smoking. This is the only cylinder like this.
Old 02-09-2006, 03:55 PM
1972_911T's Avatar
Most probably/definatly worn valve stem seals and worn valve guides, this is a common fault of the 3.2's I have just finnished rebulding mine after such issues, think its time for a top end job!
Old 02-09-2006, 04:00 PM
strep's Avatar
Can I just fix this one. All the rest are dry. The motor runs strong. It has 80,000 on it.
Old 02-09-2006, 04:11 PM
1972_911T's Avatar
You can do but the rest are sure to follow so if you wanna drop your engine again in a few 1000 miles for the sake of a few $10 valve guides and stem seals and a bit of machine shop work then yes just repairing that one may solve your problems for the time being. Do a search there are many threads on the topic of worn 3.2 valve guides.
steve
Old 02-09-2006, 04:32 PM
strep's Avatar
Looks like I am going in. Thanks I do not think anyone has heard the last of me ;-)
Old 02-09-2006, 05:28 PM
abit off center
cgarr's Avatar
Well, as long as your in there!!
______________________
Craig
G2Performance
Old 02-09-2006, 05:46 PM
1972_911T's Avatar
agh those little words, my top end refresh just ended with crank, bearings, rod bearings, piston rings, head job, arp rod bolts, oh yes and about 3 x as much as I intended to spend.
Old 02-09-2006, 06:48 PM
