zenith carb rebuild.
i took apart my carb and found that it only had two emulsion tubes in it, then i took apart the other and found that it had all three. i would assume that the first carb should also have three, is this correct? also does anyone have any info for adjusting the floats on the zenith carbs, i searched the board but didnt have much luck.
Yup, should have 3 tubes. floats are adjusted using the float level tool and shims under the check valve located in the top.
| All times are GMT -8. The time now is 09:33 AM. |
