-   -   Carb size question?? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/265477-carb-size-question.html)
Jeff Alton 02-08-2006 09:16 PM
Just curious about carb size.... 3.4, 10.5, twin plug, 1 5/8 headers, ge40ish cams..... How much power am I giving up using 40's instead of 46's?? Car is dual purpose street/track so drivability is important too. Or are the 40's just way too small??
Cheers
Steve@Rennsport 02-08-2006 10:34 PM
Jeff:
A 3.2 or 3.4 needs 46mm carbs. The venturi's can be sized for how you drive the car and what you like,.....:)
camgrinder 02-08-2006 10:34 PM
If you want to shift past 6500 rpms, I would say 40's are too small.
Jeff Alton 02-08-2006 10:52 PM
Very well then! 46's it is then!
Cheers
Wayne 962 02-08-2006 11:31 PM
40s are fine for a 3.0 or a stock 3.2 with carbs bolted on. Any increase in displacement beyond that, or a hotter cam will require the larger 46mm carbs...
-Wayne
Henry Schmidt 02-09-2006 05:14 AM
I agree with all the preceding posters. One thing to remember is that you can change the butterflies on you 40 to 44 or 46 and end up with what you need at a reasonable price.
When choosing a carburetor for track use it's important to remember that Porsche never used a 40mm carburetor on anything larger than a 2.0 and that engine used a 46 with 42 mm venturies.
