How do I get this nut off?
I am in the process of taking off the stock headers and putting on my new B&B headers. This one nut is stripped. I put in the correct hex and it spun with my fingers. The guys who put it on clearly screwed me! I've removed all the others without a problem.
How do I get this thing off?
Old 02-11-2006, 03:23 PM
abit off center
cgarr's Avatar
try the next size up? (american or metric) if thats to big you might have to grind it a bit to fit and tap it in
______________________
Craig
G2Performance
Old 02-11-2006, 04:14 PM
I tried the next step up and they (both American and metric) are too big.
Old 02-11-2006, 04:23 PM
abit off center
cgarr's Avatar
grind/file them down to fit
Craig
G2Performance
Old 02-11-2006, 04:40 PM
Super Moderator
cstreit's Avatar
You might try an oxy-acetylene torch, get it red hot then hit the edge with a long cold chisel to break it loose...
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 02-11-2006, 04:50 PM
The solution: dremel + screwdrive + hammer:
The stud made it through the surgery just fine and my careful use of magnets ensured that no metal fragments fell into the cylinder.
Old 02-11-2006, 07:03 PM
