How do I get this nut off?
I am in the process of taking off the stock headers and putting on my new B&B headers. This one nut is stripped. I put in the correct hex and it spun with my fingers. The guys who put it on clearly screwed me! I've removed all the others without a problem.
How do I get this thing off?
abit off center
try the next size up? (american or metric) if thats to big you might have to grind it a bit to fit and tap it in
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
abit off center
grind/file them down to fit
Super Moderator
You might try an oxy-acetylene torch, get it red hot then hit the edge with a long cold chisel to break it loose...
The solution: dremel + screwdrive + hammer:
![]() The stud made it through the surgery just fine and my careful use of magnets ensured that no metal fragments fell into the cylinder. |
