-   -   exhaust studs (http://forums.pelicanparts.com/911-engine-rebuilding-forum/266913-exhaust-studs.html)
philippeF 02-17-2006 03:08 AM
exhaust studs
Heloo
i've tried to heat, to hit, the snap-on tool, some WD40 to extract those "#)ù% !! exhaust studs without success
another idea ?
(2.7MFI engine)
thanks
Philippe
bbh03 02-17-2006 04:53 AM
And they didn't break either?
philippeF 02-17-2006 09:21 AM
i've stopped before it breaks...
bbh03 02-17-2006 09:45 AM
You can drill them out using the tool sold by a member here called A Quiet Boom (Christian)> I am in the process of usign that. Alos, you might try a better penetrating oil than WD40. How long were you heating it for? I was able to remove half of my studs using heat and vice grips w/o breaking them.
Determined 02-18-2006 10:23 PM
I just performed this today and also my head studs, I used my Snap On CG500 and collets. Heat was also a key in removing, it was slow and I also used an impact wrench to tighten the collet over the threads before attempting to loosen. I also found it helpful to turn it clockwise a bit then go counter clockwise, back and fourth in slow motions then when it feels loose just remove it. Good luck.
Alex
air-cool-me 02-18-2006 11:15 PM
try PB blaster insted of wd40... it works alot better!
Determined 02-19-2006 08:27 AM
Yes of course, I forgot to mention PB Blaster. I did use this several consecutive days before removal but do this in a ventillated area and let them soak overnight.
Best Regards,
Alex
