exhaust studs
Heloo
i've tried to heat, to hit, the snap-on tool, some WD40 to extract those "#)ù% !! exhaust studs without success
another idea ?
(2.7MFI engine)
thanks
Philippe
Old 02-17-2006, 03:08 AM
And they didn't break either?
-Brian
Old 02-17-2006, 04:53 AM
i've stopped before it breaks...
Old 02-17-2006, 09:21 AM
You can drill them out using the tool sold by a member here called A Quiet Boom (Christian)> I am in the process of usign that. Alos, you might try a better penetrating oil than WD40. How long were you heating it for? I was able to remove half of my studs using heat and vice grips w/o breaking them.
-Brian
Old 02-17-2006, 09:45 AM
I just performed this today and also my head studs, I used my Snap On CG500 and collets. Heat was also a key in removing, it was slow and I also used an impact wrench to tighten the collet over the threads before attempting to loosen. I also found it helpful to turn it clockwise a bit then go counter clockwise, back and fourth in slow motions then when it feels loose just remove it. Good luck.
Alex
Its easier asking dumb questions than fixing dumb mistakes
1974 Porsche 911 Coupe, RSR Project
1976 Porsche 911 Targa, Black
1986 Porsche 911 Carrera, Black
2006 Porsche Cayenne S, Black
Old 02-18-2006, 10:23 PM
Send a message via AIM to air-cool-me
try PB blaster insted of wd40... it works alot better!
SWB
Old 02-18-2006, 11:15 PM
Yes of course, I forgot to mention PB Blaster. I did use this several consecutive days before removal but do this in a ventillated area and let them soak overnight.
Best Regards,
Alex
Old 02-19-2006, 08:27 AM
