1977 2.7 911 barrel upgrade
just rebuilding my porsche 2.7lt motor just wondering wat are the maximum sized pistons and barrell i can use without machining the case thanks
Old 02-21-2006, 12:34 AM
Opening up the spigots on a 2.7 mag case is not really an option. There is very little metal between the opening and the head studs. You can go to 92mm and I think possible even 93mm (without modifying the case) however the cylinder walls get very thin.
1970 911E Sportomatic Albert Blue
1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI
1973 911E Glacier Blue
1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI
Old 02-21-2006, 10:57 AM
