3 liter to 3.7 liters?
Does any one no the specifics of this engine modification for a 1978 to1983 sc? I would like to know where I can get the pistons and cylinders to do this modification.
Old 02-17-2006, 08:26 AM
Doesn't want/need a 3.6L
Carrera3.5L's Avatar
Re: 3 liter to 3.7 liters?
Do a search, I've posted this a few times over the years.
Andial offers a conversion to go from 3.0L to 3.7L using 102mm Mahle pistons/cylinders as the basis.
Sit down when you call Pete though, they aren't cheap.
714.957.3900 or www.andial.com
Ralph
1988 Carrera w/ 3.5L Twin-Plug
2008 Cayman S (coming soon)
Old 02-17-2006, 08:57 AM
bump
Old 02-18-2006, 04:34 AM
Yeah I called them. they want 23 thousand to do this to your engine!
Old 02-20-2006, 05:31 PM
What a bargain, eh?
Just the conversion parts (piston/cylinders, Carillo rods), twin-plug components & machine work to the case alone will cost over $10K!
This is why people do 3.6L transplants now.
Ralph
Old 02-20-2006, 05:41 PM
3.6 is a bargain in comparrison!!!
Old 02-20-2006, 05:43 PM
MBruns for President
JeremyD's Avatar
Try charles at LN engineering... Ralph can't you take your 3.0 case, add a 3.2 crank and custom jugs and JE pistons? there are other ways. Also know that JB Racing in florida sell a lined cylinder combo, although not sure they go to that length
Old 02-20-2006, 07:30 PM
Jeff Alton's Avatar
LN does offer a 102mm cylinder. Use this with a 74.4 carrera crank and you get around 3645cc.
Cheers
www.turn3autosport.com
Old 02-20-2006, 07:37 PM
Hey Jeremy,
I don't know, I'm not familiar with other's products. I just know and trust the Mahle stuff. Old skool, you know?
I do know that even though it is the same 102mm bore from the 3.8L, it is still a special Mahle cylinder for the earlier 3.0L/3.2L/3.3L cases that is used exclusively for this conversion. According to Andial, the cylinder is 4mm longer so there is a proper foothold in the modified case (which has been machined down 4mm to compensate for the longer cylinder amongst other mods). I would think getting JE or someone else to make the correct piston may be easier than finding someone with the correct cylinders to make this work and reliably at that.
Small hijack, but have you gotten your motor on the dyno yet?
Ralph
Old 02-20-2006, 07:48 PM
JeremyD's Avatar
very soon my friend = very soon - been a little busy lately...
Old 02-20-2006, 07:54 PM
Jeff Alton's Avatar
Jeremy, get that thing on the dyno!! There is going to be a few good 3.4 on this board here sooon (a few more I should say). My head builder just told me my heads are going to take a month!!! Oh well, gonna have a lot of time to chassis weld etc.
I am sending my PC set to my machinist tomorrow to make sure they are okay, if they are not (like yours Jeremy) I am going 3.5 with a set of Nickies!!
Cheers
Old 02-20-2006, 09:39 PM
Will program for food
ghnat's Avatar
My 3.4 will be there some time this year....
Greg Hnat
87 Targa Disassembled
90 944 S2 Auto-x, DE and semi-daily driver
98 Jeep Cherokee
Old 02-20-2006, 09:58 PM
Jeff Alton's Avatar
Greg, keep us posted! Mine is going to take longer than expected, yes Ralph, you can laugh! Maybe should plan a "enlarged motor get together" somewhere!!
Back on topic, Crashmy911, email me directly if you decide/need the nickies.
Cheers
Old 02-20-2006, 10:02 PM
JeremyD's Avatar
Cheers
Apparently it is very common for them to be a little out of spec and a little out of round. To anybody that get's any Porsche cylinder bored - measure measure measure!
As far as busy - my house is at least coming along
Old 02-21-2006, 05:03 AM
