goldgunner's Avatar
Nose (#8) Bearing - What's the Slot For?
I'm puzzled by the longitudinal slot on the outside of the Nose (#8) Bearing opposite the locating hole-pin.
I can't see any function for the slot...is there?
Seems like an oil leak path, albeit into the O-Ring seal...
I think some people, like Henry the engine builder, recommend a thin coating of Curil-T on the O.D. of the nose bearing: what about the slot? Fill it with Curil-T?
1980 911SC - 2nd Rebuild in Process - 2005 Porsche Cayenne Turbo - 2013 VW R
________________________
2000 BMW X5 - 1996 BMW 530i - Toy 4 Runner (x2 or 3) - 1987 Toy Supra - 1988 Honda Si - 1984 El Camino Super Sport - MGA - MGB - Fiat 124 Spyder - Fiat 128 Wagon - 1962 Karmann Ghia - 1951 VW - 1953 Willys Jeepster w/Chevy 286 - 1995 Volvo 960 - 2006 VW GTI
Old 01-25-2006, 09:19 AM
That is a oil return slot. Don't fill it with anything and take care to not let any case sealant get in it. I think the bottom of the bearing may have an oil feed (not sure about that). If it does then some oil will ooze out around the bearing and be blocked by the o-ring. The oil then must have an escape path or it will leak past the o-ring.
-Andy
Old 01-25-2006, 05:03 PM
Irrationally exuberant
ChrisBennet's Avatar
Wayne's book recommends Curil-T, Henry recommends Threebond 1211 for sealing the #8.
The Threebond 1211 does the work that the O-ring and the return channel didn't do very well (sometimes). Personally, I would trust the sealing to the 1211 and fill the groove.
That said, except when I put too much 574 on the case halves once (classic newbie mistake), I've never had one leak at the #8 with or without sealant.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 01-26-2006, 06:35 AM
abit off center
cgarr's Avatar
Looking at the slot, since its midway up in the case and not at the bottom, I would guess it is there to equalize pressure and allow the o-ring to work as it should, I would not block the passage
Craig
G2Performance
Old 01-26-2006, 04:59 PM
NO GUYS !!!!
Make sure you have the right manuals at hand when putting an 911 engine back together (such as Wayne's Bible.....):
This slot MUST fit a dowel pin in one of the case-halves.
Therefore the #8 bearing must be properly aligned when mating the halves.
Not having the dowel pin in place may lead to this bearing spinning in the case instead of the crank in the bearing.....
Old 02-19-2006, 04:32 AM
goldgunner's Avatar
uh, no...
opposite the slot is the mating hole to the alignment dowel.
Old 02-19-2006, 04:34 AM
