-   -   Pistons are installed (http://forums.pelicanparts.com/911-engine-rebuilding-forum/267188-pistons-installed.html)
mppickett 02-22-2006 03:27 PM
Are you talking about having Steve do the tuning? I'm reaching the scary part pretty soon, myself (just locked down the generator and fan housing this evening). BTW, I did the heads and cam towers together like you did.
The suspense builds....
Mike
cgarr 02-23-2006 03:14 AM
Mike,
Before I even started this project I checked with Steve and he had done many similar to mine, some with more mods and some less, It will be a custom chip for my application, I will supply him with some numbers from the LM1 (and maybe even a dyno run or two) and after a few times back and fourth we should be real close on the chip..I am just used to carbs and don’t understand any of this programming stuff nor do I want to..
stevepaa 02-23-2006 08:18 AM
Very nice. How did you get the pistons all shiny? And what is the blue coloring on the crank?
