Okay, did a little mocking up today with the throttles. Need to trim the shround here and there to clear the manifolds. Getting a little bit done every day.
Also finished up the brake plumbing today and put the car back down on the ground for the first time in 9 months!!! :) http://forums.pelicanparts.com/uploa...1150609399.jpg http://forums.pelicanparts.com/uploa...1150609413.jpg Cheers |
Updates?
Kirk |
Should have some more pics later this week, been too busy to do much on it lately!
Cheers |
Jeff,
Well feel free to write up some stuff on those ITBs. I am curious what size / model Jenveys you bought, which injectors you are using, etc. Did jenvey have something premade for the porsche to handle the throttle cable? Were they lots of $$? How did you figure out the cam characteristics to handle them? What about the MAP sensor? How are you handling that? Are you going to have a common manifold they all feed into? I'm sure there are lots of us who would be happy to see you write up a small novel on what you've come up with! :) Kirk |
Jeff
Notice that you have all the Air Cond Compressor brackets fitted. Does the compressor foul No4 cyl throttle body. Have you checked this, or how did you get around retaining the A/C. Engine is 3.2 to 3.4L. I am using local made throttle bodies 50m butterfly reducing to 43mm ports, each side a one piece parallel cast. Using 803 injectors (sequential) with MoTeC M600 brain, DC24 cams, etc, etc. http://forums.pelicanparts.com/uploa...1154657102.jpg http://forums.pelicanparts.com/uploa...1154657138.jpg http://forums.pelicanparts.com/uploa...1154657162.jpg Paul |
The pic of the motor with the AC is not mine... I will update some pics tonight with the throttles on the motor. Finally got that done today!
Cheers |
Kirk, I will atttempt to answer some questions...... (wish me luck)
I am curious what size / model Jenveys you bought, which injectors you are using, etc These are 48mm straight (not tapered) throttle. We tapered the manifold to match both the intake port and the base of the throttle. I have not decided yet on the exact injector... Did jenvey have something premade for the porsche to handle the throttle cable? Nope, Ryder posted some pics a while back on his thread about how he solved it. I still have not totally figured out what I am going to do here........ This is one part that really kinda is lame considering the $$$ that these things are! Were they lots of $$? I guess so!?! :) My cost on them is pretty good, but they are not cheap! Depending on how you spec them out plan on anywhere from 2800-4000. (throttles, manifolds, TPS, rails, linkage and filters) What about the MAP sensor? How are you handling that? Are you going to have a common manifold they all feed into? Yes, MAP is built into my computer. You can see in the pics that I drilled and tapped each runner for a vacuum fitting. They will all be run together to even out the signal to the computer. I still need to see if I can "tee" some together and only have 2 or 3 lines going to the vacuum manifold (still to be fabricated) or whether I need to run all six individually to the manifold. If I can run each bank together (ie 1 tees with 2 which tees with 3 and then only a single line from there to the vacuum manifold) that would make things a little easier. That way I only need to put 2 lines into the manifold and one out to the computer. Not sure if I can do that, for some reason my head is telling me I can't.... :( How did you figure out the cam characteristics to handle them? This was the easy part! I just called up John (camgrinder) and gave him the motor specs and transmission info and where I wanted the power band and he recommended a cam to me. I went with the DC44 on a 108 lobe center. John by the way does great work, he does all my cams so I trust him to give me the straight goods so to speak. I guess it all comes out on the dyno! Hope that helps a little? I am also going to run two oil temp sensors to see which location gives me the most consitent reading for the computer. One will be in the breather cover and the other in the left chain box cover. Here are some pics of where it is at today! See the other car in the background? It is just one of the reasons I am so far behind on this project!!! :) I tried to take pics that show the linkage and vacuum ports etc. If anyone wants to see anything particular, let me know and I will snap a pic. http://forums.pelicanparts.com/uploa...1154671444.jpg http://forums.pelicanparts.com/uploa...1154671466.jpg http://forums.pelicanparts.com/uploa...1154671484.jpg http://forums.pelicanparts.com/uploa...1154671502.jpg http://forums.pelicanparts.com/uploa...1154671517.jpg http://forums.pelicanparts.com/uploa...1154671531.jpg Cheers |
Paul, those are nice looking throttles. The one peice idea is a good one. I would like to see the injector up a little higher maybe, but they look great!
What is a 803 injector? I am using a microtech (from your fine land) sequential as well! Cheers |
you, sir, are an animal... I can't wait to hear that motor sing!
Jeff
The "803" injector is Bosch part# 0 280 150 803 390cc/min flow at 2.7 bar, 57HP @ 80% duty (0.52 BSFC), 4.8 ohm impedence. check web site http://users.erols.com/srweiss/tableifc this provides reasonable data of for injector selection. The "803" was on the 944 turbo and further listed in the MoTeC manuals. Price for the "803" about 1/3 of the OEM list. Based upon 7500 rpm an engine cycle time is 16mSec thus 80% duty is 12.8mSec Following data is from 3.2L mostly standard with MoTeC for fuel and ignition, with SSI, Monty. and the "803" injectors, 98RON The following logged data from a track day may be of assistance: Air In temp = 24degC; Oil Temp = 80.4 degC; Fuel Press = 300.4kPa; Fuel Temp = 22.8degC; Barometric pressure about 0.97Bar edited to improve spacing T/Pos- RPM- MAP- La -- A/F - Duty% PW On Time 90.1% 5296 0.912 0.897 13.1 40.10 : 9.022mSec 99.4% 5854 0.956 0.863 12.7 46.60 : 9.478mSec 98.4% 4584 0.967 0.849 12.4 34.60 : 9.306mSec The maximum recorded is 46% duty, and 10.1mSec time on (not at the same time) My understanding is fuelling demand "more so" follows the produced torque curve. If you want more comprehensive data PM me your email address. I would think the "803" capable of fuel delivery for 330 to 350 flywheel HP. Confirm that your EMS is suited for 4.8 ohm injectors. Also consider the "spray patern" of injectors. Pauledited to improve spacing |
Paul, thanks for the link. That is a great table there. Lots of good info!
Cheers |
So, 3ish months since I last posted on this. Busy life (single father to 4.5 year old) and a 951 project as well. Made some progress on the car though. I find I spend too much time in the garage scratching my head and not enough time turning wrenches. OH well! Here are some pics of where I am now....
Coils mounted... .http://forums.pelicanparts.com/uploa...1170746263.jpg Here is the Jenvey linkage I fabbed to eliminate their cable linkage... |
Coils mounted... .http://forums.pelicanparts.com/uploa...1170746263.jpg Here is the Jenvey linkage I fabbed to eliminate their cable linkage... http://forums.pelicanparts.com/uploa...1170746352.jpg http://forums.pelicanparts.com/uploa...1170746370.jpg And here is the oil breather catch can I mounted (which will be painted shortly)..... http://forums.pelicanparts.com/uploa...1170746419.jpg The motor side of the wiring harness is done, so I hope to put the motor in the car next weekend! Still be a while until I start the thing (got to fix the leaky seals on the 951 engine oil cooler still :( ) Cheers |
Those MSD coils look nice.
When i was on the dyno, the guys were saying i'd probably get another 2-4hp with MSD over electromotive.... but then again they are biaset towards ramcharger 413's...lol... I am very jealous of your well planned build, top to bottom all at once...wish i did mine like that...but nope... can't wait to see it in person!!! |
Paul you can retain A/C by using the shorter body compressor from a 964 app. the brackets are the same as the earlier 3.2 stuff. |
Wow - cool build!!! That's one of the nicest looking motors I have seen!!!
It's nice to know there is someone nearby with such talent!!! I would like to get together and pick your brains about local shops, etc, and get in line for a ride when it's all done!!! |
March 1st is the first "garage and beer night" at my place for the local crowd. You are more than welcome to attend. Beer is on me. You can email me using the link by User ID and I can give you the details. You are welcome to come by anytime to chat.
Cheers |
Wish I was a little closer, I would love to drop by and check out your progress!
Kirk |
So, nearly two months later it almost ready to go in. Pulled it off the stand tonight, put the trans on and the starter. Just got to pull the bumper tomorrow and in she goes........
http://forums.pelicanparts.com/uploa...1175314514.jpg Cheers |
Jeff,
That's sweet, can't wait to see what the dyno shows. Doesn't look like it will be long before you will be enjoying the power.:cool: |
Jeff, That's just beautiful to look at. Nice job!
WOW, nice looking engine, i'm sure it will sing!!!
how did garage and beer night go at your place? any picks from that? |
It was postponed due to a family emergency. Hoping to get it done when the twin plug turbo motor shows up for assembly.....
Cheers |
Jeff,
The motor looks great! Hope the install is going well. Kirk |
Looks sweet Jeff!
-Chris |
So, I had an hour of spare time tonight, for a change and look what happened!!!!
From this: http://forums.pelicanparts.com/uploa...1175830961.jpg To this: http://forums.pelicanparts.com/uploa...1175830982.jpg And that leaves this for the twin plug 3.3 turbo motor to land on: http://forums.pelicanparts.com/uploa...1175831015.jpg I heard the car sigh (it has not seen its motor for about 18 months) and then I saw a wet spot on the floor underneath it..... :) Cheers |
wow, looking nice!!! i bet your dancing around like a 4 year old who needs to pee...
who's 3.3L turbo will you be building? i'm assuming there will be a thread on it? |
That is too funny, my 4 year old does indeed dance we he needs to pee! Hmmmmm, I opted to open a nice bottle of wine instead!
The 3.3 is for a local customer. His car has been apart since the early 90's!! He had the heads rebuilt and twin plugged right at Garretsons right before they went out of business. He had to drive down there to get his parts back but I think he got some good buys while he was there..... Yes, I will post a thread about the build, it won't take nearly as long as there is a 3.2 build pending as well. My own stuff takes so long because it takes a back burner to other's needs. Cheers |
Sweet! Glad to see it!
Jeff,
Good luck with the fire - up process! Looking extremely sweet! Doug |
Thanks guys, hoping to finish up the wiring in the next few days. Have not had any time this week yet to work on it...
Cheers |
Well, the next few days turns into the next few weeks......... :) The coils and igniton are done, same as the fuel plumbing. I have had zero time to work on this thing. But, I did manage to get the oil cooler baffle and oil cooler in.....
Here is the cooler and baffle... http://forums.pelicanparts.com/uploa...1181452941.jpg http://forums.pelicanparts.com/uploa...1181452964.jpg and here are the ecu/ignitor box and the harness. They will be mounted on the firewall. http://forums.pelicanparts.com/uploa...1181453027.jpg http://forums.pelicanparts.com/uploa...1181453057.jpg And the digital dash will be in one of the two places shown in red..... http://forums.pelicanparts.com/uploa...1181453100.jpg Cheers |
Jeff,
Really like that oil catch can/ breather pictured in the last shot of your motor. Who makes that little guy? |
That one is made by Moroso. It has a drain on the bottom that I ran out below the car with a petcock on it. I also had to cut down the filter to fit it in there where I wanted it.
Cheers |
That backseat looks familiar. Did you lay things out on the floor before tossing it all in? I went back and did that to help with the mental picture.
Best of luck. |
It is all just sitting there right now, tonight I will seperate the harness (on the floor beside the car) to figure out which wires need to pass through the fire wall and which ones don't.
Cheers |
Well, progress is slow, but I am getting closer now...
The car (ecu) is now communicating with my laptop....... Everything is wired in and I just have to connect the fuel filter and the fuel lines in the engine bay. I am bringing the ECU tuner up to the garage for the initial start up to make sure it fires, then we are towing the car to the dyno for a break in and tunning. http://forums.pelicanparts.com/uploa...1185170300.jpg http://forums.pelicanparts.com/uploa...1185170330.jpg http://forums.pelicanparts.com/uploa...1185170347.jpg Cheers |
bookmarked
Jeff,
Looks like you are getting close now! Be sure to take lots of pictures of the dyno runs and ECU tuning. I am sure there are alot of us who are interested in the details! Kirk |
Kirk,
The whole break in and tuning process will be extensively documented. I will highlight what I did right, what I screwed up, and what I would do differently. I will be sure to say "this worked" and "this idea didn't work". The tuning will be a learning process for me, first time using a computer as my hand tools...... :) Cheers |
| All times are GMT -8. The time now is 08:40 PM. |
