Need 2.7 engine pics
Does anyone have pics of their 2.7 engine. especially from the rear. Can't remember where all of the wires and hoses go. I read Wayne’s book 101 projects too late.
Hi
I got a 1975 2.7 at home in the garage. But i wont be home until Thursday, If you have not recieved any by then I'll take some and send them on to you by email. Did you rebuild the engine? As I am about to under take rebuilding mine very soon. Niall |
I should have but only did the most common oil leaks. I forgot to mention that I have a CIS system. Thanks for the reply look forward to seeing the pics.
Thanks Brian |
I have a 77 w/CIS in the garage... I'd be happy to snap some pics... what specifically are you looking to clarify?
-- Joe |
I have some electrical connections I can't remember where they go. I know the blue connector goes to the cold start. Black connector goes to the back of the air box. One gray connector goes to warm up, and they can't find were the other gray connector goes. If you could take some photos of the wiring connections and the breather lines. That would be a tremendous help.
Thanks Brian |
i dont know how much this is going to help but heres the pics of my 2.7. It doesnt look the same now as ive cleaned it up quite a bit but this is all i have...i hope this helps.
http://img.photobucket.com/albums/v2.../924Car678.jpg |
Here's my 2.7 patient currently going under the knife :)
http://forums.pelicanparts.com/uploa...1140488805.jpg http://forums.pelicanparts.com/uploa...1140488821.jpg http://forums.pelicanparts.com/uploa...1140488847.jpg 2.7 harness under FI as they lay in place... http://forums.pelicanparts.com/uploa...1140489444.jpg http://forums.pelicanparts.com/uploa...1140489469.jpg http://forums.pelicanparts.com/uploa...1140489500.jpg and some from a Euro 3.0 also going under the knife... http://forums.pelicanparts.com/uploa...1140488972.jpg http://forums.pelicanparts.com/uploa...1140488986.jpg http://forums.pelicanparts.com/uploa...1140489013.jpg Hope it helps... Lou |
Thanks Lou, Attached is one of your photo's that may clear up my mystery. I hope someone tagged the wires.
Thanks Brianhttp://forums.pelicanparts.com/uploa...1140492273.jpg |
I think the one with the "?" goes to the air valve that controls fast idle. It is located on top of cyl #5. Otherwise they look good. Lou
Thanks Lou, Just one more question. Is the connector to cly#5 Black?
Thanks Brian |
yes.... Just found another pix... Louhttp://forums.pelicanparts.com/uploa...1140558430.jpg
Thanks so much for your help.
Brian |
My Pleaseure!! Lou
| All times are GMT -8. The time now is 01:05 PM. |
