-   -   Where is this leaking from? Help!! (http://forums.pelicanparts.com/911-engine-rebuilding-forum/267484-where-leaking-help.html)
kellyporsche 02-20-2006 01:36 PM
Can anyone tell me what needs to be replaced in this area. When under acceleration oil comes up from this area (drips when idle or not running). The oil is not coming from the upper valve cover side, but from under the fiberglass engine shroud. It looks like a gasket needs replaced? I can’t seem to figure it out after reading the manuals I have. Any help?
http://forums.pelicanparts.com/uploa...1140471285.jpg http://forums.pelicanparts.com/uploa...1140471304.jpg http://forums.pelicanparts.com/uploa...1140471328.jpg
JoeMag 02-20-2006 02:19 PM
the only thing there is the head / cam tower mating surface. it's a metal to metal seal.
i had pic to post but don't know who to do on reply
WERK I 02-20-2006 02:43 PM
How does it look from the underside, between cylinders/heads and the heat exchangers?
Also, keep in mind that the fiberglass cover is a point of higher pressure due to cooling fan pressurizing that plenum. Without that cover off, it is difficult to give a definitive answer.
kellyporsche 02-20-2006 03:14 PM
Last week I disassembled the air intake etc. and noticed nothing! Now I am having this leak and there are no signs of it coming from the bottom. This is what has been bothering me?? I am taking the intake back off and will post more pics. Still need some help!
Thanks!
