Oil-fed chain tensioner question
Is there supposed to be a large gap between the chain tensioner and the spacer on the idler arm shaft? I have a gap of at least 2mm here on both sides. It doesn't look right. Any advice?
http://forums.pelicanparts.com/uploa...1140749380.jpg |
That's what mine looked like, too.
mpp |
Just did mine and found the same thing, they kind of float there
The teeth on the gears look good too.
Good luck. |
it floats...
What is the history/situation.
Is there a reason that led you to the tensioners? Why is the chain cover removed in the first place? Since you can't replace the chains with one piece chains, there shouldn't be much necessarily wrong there. But Mike Bruns at JB racing in Fla has some mean solid tensioners available. Regards, |
When in the disassembly process how loose were the chains? How much wear do you notice on the parts in question? The chains are very strong and unless stretched should hold up until you need to get into the bottom end (for a complete rebuild). The tensioners should hold up very well, unless there has been an oil starvation incident/situation.
Has physical inspection revealed if there is any significant wear on the tensioners, any of the gears, or the stud. Regards. |
There is very little wear on any of the timing chain components. I'm not planning to replace any of them. |
| All times are GMT -8. The time now is 05:13 PM. |
